Home > Puma (Tdci) > Gap IID Tool Steering angle sensor reset |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
There is no steering angle sensor on 2.4...
Only fitted to the 15MY Defenders with the Bosch ABS setup. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
21st Jan 2023 4:55pm |
Grizwold Member Since: 21 Jan 2023 Location: Lincolnshire Posts: 15 |
Thanks Ian, it was always going to be my mistake!
Although, is it correct that the only ECUs in car config are IPC and VIM? Thanks again |
21st Jan 2023 5:00pm |
...and its back to the drawing board trying to diagnose abs fault!
21st Jan 2023 5:04pm |
You should have PCM, IPC and ABS... but i've never used a GAP tool.
Your Defender is fitted with the earlier Wabco set up, which apart from Shuttle Valve and Pump issues is normally quite reliable. I'd be checking all the wheel bearings for excess movement, and I'd reset all the sensor clearances. As intermittent faults are often casued by the sensors being on the limit of distance between the reluctor ring. You could try giving all 4 sensors a gentle tap to ensure they are pushed in far enough - no need to go mad and smack them with a lump hammer, but a gentle tap to ensure they are pushed in enough is fine. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Great, thanks mate, all good information and much appreciated, I'll have a play with sensors next. I was probably just trying the easy bits first without getting jacks and spanners out!
21st Jan 2023 5:08pm |
No need to get the jack out or wheels off... are quite accessable. Just give them a gentle tap down with a little hammer. IRB
21st Jan 2023 5:10pm |
yep, just climbed underneath and checked sensors, you're absolutely right - the front nearside visibly drove home about 1mm or so after a tap with a nylon mallet.
Fingers crossed that might be it, won't know until a test drive tomorrow, but thanks again for that bit of advice that may have saved a lot of pain and expense. I hope not to be too much of a regular burden on this site, but its great to know there are people out there willing to share their Knowledge. Cheers |
21st Jan 2023 5:32pm |
