![]() | Home > Technical > Retrofit CDL to '99 TD5 |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
I know you’ve already sorted the EW but this might help?
https://www.lrparts.net/lr016315-front-doo...cking.html ![]() Click image to enlarge |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 ![]() ![]() |
Do you have a 10AS that supports CDL? - if so you can activate it and then just run the wires from the 10AS unit to your CDL motors. If you don’t you can buy one by exchanging it for your unit.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6141 ![]() ![]() ![]() |
^^^ I've got, somewhere, the destructions on how to convert a non-CDL 10AS into a CDL version. adding a relay is about all it is.
And from other threads I read you can tap off of the PCB the feed that would normally control the onboard relay, to power an external CDL relay, thus using a non CDL 10AS to operate CDL. |
dp7 Member Since: 10 Sep 2022 Location: HW Posts: 3 ![]() ![]() ![]() |
Late to respond. Ended up going with Pace Automotive to build the required looms for CDL and power windows and 10AS upgrade. Entirely reasonable price and great quality.
