![]() | Home > Td5 > Misfiring and struggling with power. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5261 ![]() ![]() |
Right o this is biting me now, i cannot get the car through an mot, at all.
![]() When we had all this rain back in November, the car started to run erratic, and struggled like hell to get to 40 mph. To the point i had to pull over and let it sort it self out. I checked the ECU for oil, and cleaned and replaced the harness for the injectors. Made no difference at all. I bought a cheap Crank sensor, still the same trick, ( em light on this time) I got someone out to put the car on diagnostics got a few error codes. dirty crank sensor, and crank high signal lost. ![]() Click image to enlarge Changed the crank sensor back to the original unit, and i have just wired in a replacement loom and i am still in the same boat here. I have changed the foot pedal just rule that out, its had a new Maf sensor in, and i did unplug that and the same with the one in the air box, Car still behaved the same, Turbo wastegate is nice and free, i am getting a lot of smoke out the exhaust when i rev it, i am not sure if the fuel pressure regulator is acting up or what? Seems to be a bit of oil under that area where the starter motor is. Any ideas on what else it could be? before i book it in to a land rover specialist Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I did the fuel pressure regulator on my one with the X8R kit, i didn’t have any normal running issues but it wasn’t happy pulling our 3.5 tonne trailer and started dripping diesel over the gear box.
Make sure you have a 3/8th torque wrench and a selection of extensions. Only takes about an hour. https://x8r.co.uk/land-rover-td5-mk2-ii-di...epair.html Are you getting any oil dilation? Is the Oil level going up? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5852 ![]() ![]() |
When smoke? What colour smoke?
its white smoke, when you rev it and it starts to miss fire. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
andylee Member Since: 29 Jun 2016 Location: South East Posts: 98 ![]() ![]() |
Swap out the fuel filter and introduce some injector cleaner to the fuel such as Millers Diesel Ecomax.
I've had rough running and misfires caused by an old fuel filter before. good luck A |
Could it be possible that you have water in your fuel tank?? How old is the filter? Tried draining some off the filter?
i did drain the fuel filter off, just to see if it was water in diesel. I will switch it over with another one, just to see if the fuel filter is damaged. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
have you done a sniff test to check the coolant to make sure its not the head gasket? You don't always get mayo in the oil.
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 916 ![]() ![]() ![]() |
Check the fuel pump relay.
Mine failed recently and, before leaving me stranded, the 90 was down on power and would give off white smoke when trying to boot it over 2,500RPM. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
you got a part number for it? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
YWB000150 Charlie
i will give that a try for the sake a few quid
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Just swap it for one of the other relays to try 02' 110 TD5 Double Cab Rebuild Thread
I think this may have cracked it like, Just fired the car over, before hand it was idling bad, and puffing smoke. Powered the motor off, and had a bit of play with the relays, Mine seems to be the one in the middle. So swopped that for the new one, and it fired as normal. revved it a bit and it seems to be happier, and i put the car in reverse and it didn't start miss firing. My dad said it sounds happier, he said change the fuel filter on it just with it been standing, so i will do that when it dries. We will see though how the car performs though, because i have been lead down it seems ok before and its not ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
