Home > Td5 > Misfiring and struggling with power.
Procta
Right o this is biting me now, i cannot get the car through an mot, at all. Rolling Eyes
When we had all this rain back in November, the car started to run erratic, and struggled like hell to get to 40 mph. To the point i had to pull over and let it sort it self out.
I checked the ECU for oil, and cleaned and replaced the harness for the injectors. Made no difference at all.
I bought a cheap Crank sensor, still the same trick, ( em light on this time) I got someone out to put the car on diagnostics
got a few error codes.
dirty crank sensor, and crank high signal lost.
Changed the crank sensor back to the original unit, and i have just wired in a replacement loom and i am still in the same boat here. I have changed the foot pedal just rule that out, its had a new Maf sensor in, and i did unplug that and the same with the one in the air box, Car still behaved the same,
Turbo wastegate is nice and free, i am getting a lot of smoke out the exhaust when i rev it, i am not sure if the fuel pressure regulator is acting up or what? Seems to be a bit of oil under that area where the starter motor is.
Any ideas on what else it could be? before i book it in to a land rover specialist Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #978027 14th Jan 2023 6:02pm
kenzle8a
I did the fuel pressure regulator on my one with the X8R kit, i didn’t have any normal running issues but it wasn’t happy pulling our 3.5 tonne trailer and started dripping diesel over the gear box.
Make sure you have a 3/8th torque wrench and a selection of extensions. Only takes about an hour.
https://x8r.co.uk/land-rover-td5-mk2-ii-di...epair.html
Are you getting any oil dilation? Is the Oil level going up?
Post #978048 14th Jan 2023 7:02pm
roel
It could be the injector seals.
You don't really need an oil level increase for you injector seals to give problems. Roel
2003 90 Td5 (2009-now)
Post #978054 14th Jan 2023 7:20pm
landy andy
When smoke? What colour smoke?
Post #978094 14th Jan 2023 9:52pm
Procta
its white smoke, when you rev it and it starts to miss fire. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #978103 14th Jan 2023 10:48pm
andylee
Swap out the fuel filter and introduce some injector cleaner to the fuel such as Millers Diesel Ecomax.
I've had rough running and misfires caused by an old fuel filter before.
good luck
A
Post #978187 15th Jan 2023 4:06pm
landy andy
Could it be possible that you have water in your fuel tank?? How old is the filter? Tried draining some off the filter?
Post #978195 15th Jan 2023 4:38pm
Procta
i did drain the fuel filter off, just to see if it was water in diesel. I will switch it over with another one, just to see if the fuel filter is damaged. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #978201 15th Jan 2023 5:06pm
kenzle8a
have you done a sniff test to check the coolant to make sure its not the head gasket? You don't always get mayo in the oil.
Post #978215 15th Jan 2023 6:02pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Check the fuel pump relay.
Mine failed recently and, before leaving me stranded, the 90 was down on power and would give off white smoke when trying to boot it over 2,500RPM. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #978216 15th Jan 2023 6:04pm
Procta
you got a part number for it? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #978229 15th Jan 2023 7:04pm
BaronDefenders
YWB000150 Charlie
2002 Td5 90 (SOLD)
Post #978231 15th Jan 2023 7:18pm
Procta
i will give that a try for the sake a few quid Thumbs Up I know relays do tend to go on the blink when they hit a certain age. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #978246 15th Jan 2023 8:36pm
rallysteve
Just swap it for one of the other relays to try 02' 110 TD5 Double Cab Rebuild Thread
Post #978253 15th Jan 2023 9:09pm
Procta
I think this may have cracked it like, Just fired the car over, before hand it was idling bad, and puffing smoke.
Powered the motor off, and had a bit of play with the relays, Mine seems to be the one in the middle. So swopped that for the new one, and it fired as normal. revved it a bit and it seems to be happier, and i put the car in reverse and it didn't start miss firing. My dad said it sounds happier, he said change the fuel filter on it just with it been standing, so i will do that when it dries.
We will see though how the car performs though, because i have been lead down it seems ok before and its not Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #978841 19th Jan 2023 5:31pm
