Home > In Car Electronics > Reverse signal feed
Poulstonb
Reverse signal feed
Finally decided on my double don conversion and rear camera .
I need to pick up a reverse signal feed somewhere behind the stereo so the camera activates when reverse engaged.
Any ideas ?????
Post #978021 14th Jan 2023 4:29pm
roel
I think the closed is at the top off the gearbox. Roel
2003 90 Td5 (2009-now)
Post #978050 14th Jan 2023 6:05pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
I’ve just replied to your other post, this is the connector for the reverse switch, left hand side of gearbox.
Post #978065 14th Jan 2023 7:02pm
Poulstonb
So do I tap into the green or grey wire ?
Post #978069 14th Jan 2023 7:28pm
Penfold_6290
The wires are GN (green with brown trace) and GY (green with yellow trace). You want the green and brown wire as that will become live when the vehicle is in reverse and the reverse switch is closed.
Post #978070 14th Jan 2023 7:30pm
Poulstonb
Perfect thanks
Post #978075 14th Jan 2023 7:40pm
GM_FFX
United States 1992 Defender 90 200 Tdi HT Rimini Red
did you end up tapping into those wires? How did you get to them?
Post #980392 29th Jan 2023 7:36pm
Poulstonb
Wires
No the camera had an additional wire that was spare and ran with the jack lead, I connected the reverse signs feed to it on the head unit , then at camera end cut it and spliced into the reverse light live .
Post #980411 29th Jan 2023 10:02pm
GM_FFX
That's what I was thinking too, quick question, does the camera have a delay function or the screen constantly turns off while parking and shifting from reverse to first gear?
Post #980419 29th Jan 2023 10:46pm
Poulstonb
Just switches on/off when reverse is selected
Post #980432 30th Jan 2023 7:02am
