Home > In Car Electronics > Wipers won't turn off?
Page 2 of 2 <12
spudfan
Ireland
Try replacing the stalk. Not too expensive or hard to do. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #977565 11th Jan 2023 12:20pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I know it sounds weird, but have you got anything 'plugged in' to the cigarette lighter?
The reason I ask, is that my wipers were behaving very strangely last Sunday.
They were switched off at the stalk, but were stuck 'on' at normal speed. Moving the stalk to high speed worked, and they sped up, but both off and intermittent (at the stalk) resulted in the wipers being 'on'.
I was charging my son's ipad via the cigarette lighter socket at the time. Once I removed the charger from there, it all went back to normal. I was so surprised by this, I pulled over and rechecked it all. And yes, it was entirely repeatable.
Whether this is just a feature of the electronics, or perhaps the earth on my wiper system is not perfect and is somehow earthing via the lighter socket... I've not yet checked.
Hope that may be of help!
mine's a 2014 Puma, so may or may not be the same!
Post #977566 11th Jan 2023 12:27pm
Almost certainly this, I'd say. Darren
Post #977570 11th Jan 2023 12:41pm
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
That is an interesting fault! Just checked and nothing plugged in so going to get a stalk ordered and swap that out and see what happens.
Post #977581 11th Jan 2023 1:50pm
Was it a Britpart park switch?
It is possible that the new park switch has also failed, or that the grease in the motor gearbox is so gungy that it has caused the new park switch to stick.
Post #977590 11th Jan 2023 2:20pm
TamarBlue11
Nah not bridpart luckily. Wonder if its worth trying the stalk first as that seems alot easier to replace then pulling the wiper motor or doing the switch again!
Post #977622 11th Jan 2023 5:20pm
TamarBlue11
Plot thickens... fitted a new wiper stalk no difference so can't be that.
However have noticed that wipers do stop and operate properly when the ignition is on just not when the engine running. Not sure what that could mean??
Post #977991 14th Jan 2023 1:22pm
TamarBlue11
After some thought think I'm going to try a new motor and see what happens. Don't want to open the dash up again and not have one ready.
Has anyone got any recommendations on what repair kit to get? I may as well swap it all out I think.
Post #978235 15th Jan 2023 6:38pm
Page 2 of 2 <12
