Home > Modifications & Maintenance (L663) > Headlamp Power Wash
graemesmith1960
Headlamp Power Wash
Had my MY22 D300 HSE 110 for almost 10 months and I just noticed it does not have Headlamp Power Wash! I never even thought to spec it as I had naively assumed that a reasonably hi spec vehicle would have that as standard.
Has anyone tried to retrofit it? The parts are around £100 + VAT (excluding new headlight surrounds which are about £120 each).
I'm assuming all the wiring will be there but will it need the CCF updating? Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #976006 29th Dec 2022 7:09pm
Defendit..
Netherlands
Did not do it yet, was looking into how to.
I think the headlight surrounds can be modified, saving some.
Not sure about the washer pump.. could be an additional one as you can read below.
 No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #976042 30th Dec 2022 9:10am
graemesmith1960
Thanks, yes, it is an additional pump but it's only £30 or so. The main issue is if the CCF needs modifying. More research needed! Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #976043 30th Dec 2022 9:32am
Defendit..
Netherlands
Ok Graeme, I'am interested
How about the wireloom/harnass ?
Hoses / splitter ?
When I was rebuilding after respray, 2 hoses and 2 connectors are attached to the Washer fluid reservoir.
GAP IIDtool ?
Post #976053 30th Dec 2022 10:45am
graemesmith1960
Thanks for that.
I have had to send my IID Tool back to Canada as it is too old for the Beta program. Once I get a new one I'll have a good look and see if there is anything in there. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #976076 30th Dec 2022 2:21pm
rtm89
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
Very interested to hear if you get orted with retro fitting this. Running one without is a complete nuisance.
Post #977742 12th Jan 2023 2:23pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
There is a setting in the CCF to turn it on
MultiCAN-728 Headlamp Wash
Fitted
This is from the ccf on my car which has them fitted Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #977764 12th Jan 2023 3:55pm
Defendit..
Netherlands
Hose front between the washer Jets LR 132136
Jet . LR 132137
Jet. LR 132138
Washerpump for headlights. LR 129849
Still no info over the wireloom...
Post #983755 26th Feb 2023 1:58pm
