Home > Technical > Beware of Britpart panhard rods...
fumiyasu
 1999 Defender 110 Td5 SW Santorini Black
I have been renewing my panhard rod bushes which is the later bigger diameter type and accidentally chipped a bit of the original rod away on removal, so I went and got a new rod as I wanted everything nice and shiny.
It's obviously not news that Britparts aren't generally recommended but in this case the gen part is out of stock and only Britparts was available. So I thought it was probably ok given it is a simple metal part. I also had the full superpro poly bush kit which I could replace the Britparts bushes with. Anyway, big mistake...
Got the new rod, pressed out the BP bushes pretty easily but the poly bushes won't go in easily like the usually do. Lots of fiddling and I got them in but wasn't 100% flush, that meant it was very hard to mount to the truck and in doing so I damaged the bush. So I thought perhaps the poly bushes weren't designed correctly and got some gen LR panhard bushes. Pressed it in about 80% and the rubber started squeezing out...
It then occurred to me perhaps the diameter of the hole is too tight. Measured the original rod and the new rod with a caliper and it was a full 1mm difference...
So anyway, my advice is, if using Britparts, just leave the BP bush in and replace the whole thing every so often. If not then measure the hole before attempting to press another bush in...
Post #975910 28th Dec 2022 9:01pm
fumiyasu wrote:
... I thought it was probably ok given it is a simple metal part. ...
A mistake which so many have made! Never underestimate Britpart's ability to mess up a part of great simplicity. Big Cry
Post #975919 28th Dec 2022 10:21pm
kenzle8a
I just bought a second hand oe one from eBay for £10 and painted it and fitted the super pro bushes,
Post #975927 28th Dec 2022 11:38pm
Procta
id look at finding some second hand units and doing those up Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #976030 30th Dec 2022 2:01am
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
leave bearmach alone as well, total pants
Post #976459 2nd Jan 2023 9:02pm
KISSMYAURA
cant praise supapro enough did the full set very happy.
Post #976460 2nd Jan 2023 9:02pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Went bankrupt, no longer an option...
Post #976465 2nd Jan 2023 9:30pm
fumiyasu
Yeah, I am looking out for a good condition second hand one now. But in the meanwhile have the Britparts with Britparts bushing on... Let's see how long this lasts... Rolling Eyes
Post #976683 4th Jan 2023 5:53pm
