Home > Puma (Tdci) > Pumas clutch replacement |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
A well-equipped garage with experience of the job working on a clean vehicle and nothing going wrong could do it in around three hours. If things are seized or break it could extend to a full day. It's unlikely to be more than a day unless something goes fairly drastically wrong or there's a significant problem.
22nd Dec 2022 10:11am |
Matthew Member Since: 22 Dec 2022 Location: Neath Posts: 3 |
Many thanks
23rd Dec 2022 9:35am |
cretesimon Member Since: 01 Nov 2021 Location: heraklon Posts: 51 |
Also ask the garage to quote you the book time as most good places will have a program which states the time a job will take make sure they replace the full kit including slave cylinder
27th Dec 2022 7:22am |
Many thanks
27th Dec 2022 11:00am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 826 |
Matthew,
You should give Simon @ Lewis Bespoke Vehicles a call . He’s in Crynant. An LR specialist. 07970692061 2008 2.4 110 Utility Station Wagon XS. |
27th Dec 2022 2:53pm |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
...also (as suggested by Cretesimon), if you've got the gearbox pulled back to get to the clutch, at 70k I'd be tempted to change (to the point of actually doing it) the slave cylinder which sits INSIDE the bellhoiusing and requires the gearbox out to get at it, unlike everything pre-puma where it was on the outside and could be chanaged with a beer in one hand, a spanner in the other and a quiet chortle...
If your slave cylinder goes, its a whole world of pain and upset (and expense unless youre doing it yourself) when you realise the gearbox has to come off the engine to have it changed... Ask me how I know. |
4th Jan 2023 6:51pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
A day really, shouldn’t be any longer unless a problem develops which is unlikely. $W33T $0U7H3RN $UG4R
4th Jan 2023 7:45pm |
