Home > Modifications & Maintenance (L663) > Thule roof bars - edge or no edge?
XplusYplusZ
I’m looking at buying a set of roof bars. Can’t decide if to go for the more integrated style bars which have no overhang past the fixing feet - these are branded “edge” by Thule, and look similar to the landrover OEM crossbars. OR are there benefits in going for the less integrated styles where the bars extend beyond the fixing feet.
I have a Thule Canyon roof basket that I’ll be fitting. I’m thinking the overhangs could be useful to help with straps and camping. But I think I prefer the cleaner look of the integrated style..
What’s the general consensus here?
Post #973218 2nd Dec 2022 5:04pm
Defendit..
Netherlands
It's very personal I think.
I did lower the Thule wingbar Edge , only 5mm above the sharkfin.
Nothing to worry and quiet on the Highway. Clean look
 No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #973220 2nd Dec 2022 5:08pm
XplusYplusZ
Thanks mate - it does look nice and clean. Are the feet locatiosn fully adjustable, or are you forced to use just the 3 points on the bars?
Which bars lengths did you need?
I find the Thule site and instructions far less intuitive than they may think it is. Fitting kits, feet bar length etc. I just have a feeling I'm going to be ordering the wrong parts..
For example, I was looking at this set below. The site says it's compatible, but the picture is definitely not t-track flush bars..
confusing.
Post #973237 2nd Dec 2022 6:56pm
I think that the T track mentioned in that advert is in the bars themselves to allow fitting of accessories rather than the method of fixing them to the roof. Darren
Post #973271 2nd Dec 2022 10:27pm
Defendit..
Netherlands
Thule Wingbar Edge 9595. M + L
Did not use the podiumfeet, instead made new brackets and shaved the caps a little.
Post #973291 3rd Dec 2022 9:23am
miker
Looks smarter, but significantly less usable length on the edge style bars. I had the normal wing bars on my previous Skoda estate and just took them off when not in use...
Post #973292 3rd Dec 2022 9:24am
haymeister
Japan
I have the non-edge installed. Extra length can't go amiss Whistle
Easier to install roof box and ski/snowboard rack with the overhang as you said.
I have the Thule Wingbar Evo (753 for the feet, 7113 for the bars (mine are black), and 3040 for the fit kit)
Some pics taken from my IG
 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #973426 5th Dec 2022 1:05am
XplusYplusZ
You say 9595 (as do a lot of other people). But the Thule site is saying the defender needs 95cm and 86cm..
Do you know why there's a difference?
I wonder if the newer designed feet(720700) means the 95cm will be too long at the rear?
Post #974039 9th Dec 2022 12:53pm
Jtt74
Do people with crossbars keep them on all year round?
I can't make up my mind if it looks ok or not, any issues with wind noise etc?
Thanks,
Post #975271 20th Dec 2022 5:30pm
haymeister
Japan
I am purely functional, I take them off when I don’t need them.
1. Slightly less buffeting and whistling at speed (Thule are one of the better ones IMO but you need to install the rubber seals properly)
2. Less anxiety in <2m car parks.
3. Does look cleaner. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
Post #975417 22nd Dec 2022 12:44am
XplusYplusZ
So here's what I ended up with - the latest version of Thule's New Defender solution:
https://www.thule.com/en-gb/roof-rack/roof...e-_-720700
Fitting Kit 187122
Fixpoint Edge Foot Pack 720700
Wingbars 95 95
I'm not particularly happy with the base/fitting kit, they seem to sit very high - especially considering the fixed rail is already raised.
The fitting kit plastics which attach to the feet is quite awkwardly shaped and doesn't seem to mate with the feet very well. It looks a little botched together when compared with other kit/feet pairings. Especially when compared to the non-edge examples. The foot overhangs the fitting kit. The fitting kit tapers thin, then the foot bulges out again.. Aesthetically, it's disappointingly ugly.
The fitting kit/foot connection looked odd enough that I had to check the instructions multiple times to confirm this was indeed the right way to fit them:
I am considering a similar approach to Defendit's posts above - potentially shaving the plastics of the fitting kit down. The upper metal bracket is pretty complicated. With a latch system to attach the bars. The lower is simply a rectangular plate and bolt which slides along the inside of the integrated roof rail.
Fortunately, they're currently hidden below a pretty ugly roof basket. But I will be removing the bars when not in use with a box/basket.
Post #975463 22nd Dec 2022 1:24pm
