![]() | Home > Tdi > Testing of 300Tdi injectors |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1237 ![]() ![]() ![]() |
Injector pressures are given in the workshop manual:
![]() The main thing with them is that they all crack off at a similar pressure (better to have them even and low or high rather than uneven across the board) and you get a nice clean jet coming out of all four orifices (I think it's four, can't quite remember). A friend in Surrey had a manual tester for them and I was amazed at how simple the job actually was, we were also able to put through a lot more diesel than would normally be given by an injector pump which helped clear out the nozzles from build up. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
It's the primary and secondary pressure that is worrying me, not sure how to do this.
My tester can go to 600 bar but it's fully manual, like one lever. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 643 ![]() ![]() ![]() |
I have a Hartridge Testmaster 2 computerised tester, which was over £5000 new, and even that cannot test 300tdi injectors fully without a secondary pressure add on at another couple of thousand pounds.
With a standard tester like the hartridge you can still test the primary pressure, spray pattern and leak back time, so it gives you a pretty good idea of injector performance. I have found that stripping the injectors down and cleaning them / ultrasonically cleaning the nozzles and reassembling can cure a poorly performing 300tdi injector. 300tdi injectors have five ports, and not quite evenly spaced around the nozzle, |
Thanks for your reply. Not the answer I wanted to hear but the answer I was expecting.
I didn't think it was going to be that easy to test them. |
Rovadon Member Since: 20 Apr 2015 Location: Vancouver Posts: 5 ![]() ![]() ![]() |
I was gonna try this…
https://mercedessource.com/store/diesel-fu...t-yourself |
