Home > Puma (Tdci) > Front heated windscreen relay Puma MY12 where to find?
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
Front heated windscreen is not working. Don’t hear a klick
When I push the button. Trouble in finding the right fuse and relays
Can only find the rear heated windscreen relay. But as it is an 130 it hasn’t any...
On pictures I see RHD has a mirrored fusebox under the steering wheel. Is my assumption correct?
Please help
Regards
Quirin
Post #815431 16th Feb 2020 4:16pm
Martin
Site Admin
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #815433 16th Feb 2020 4:27pm
TopQ1967
Thank you very much. Still no power at the switch but know where to look at now.
Regards
Quirin
Post #815444 16th Feb 2020 5:32pm
Martin
Site Admin
OK the switch is just used as a trigger for the timer. The lamp in the switch is in parallel with the output from the relay, so it only illuminates if the screens are switched on.
If no 12V supply on the white/green wire with the key in position 2 (ignition on) then check fuse 4, but this supplies other things like the instrument pack, headlamp relay and the relay which supplies the heated seats and electric windows (if fitted).
Otherwise the main supply to the screen relay is Fuse 7 under the seat.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #815452 16th Feb 2020 5:42pm
Gillan
United Kingdom 2009 Defender 110 Puma 2.4 HT Alaska White
Hi I thought the relay for the front screen was under the seat with the air con relays etc
Post #815489 16th Feb 2020 7:24pm
Martin
Site Admin
Not on the 2.2 Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #815490 16th Feb 2020 7:24pm
Gillan
Bow down
Post #815498 16th Feb 2020 7:41pm
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
@martin
I am having a stinker trying to resolve my heated screen issue. 2.4 puma
My switch doesnt show a light when pressed at all with the car running.
With your comments above, am i right in thinking if i dont have any light in my switch, the light is powered from the heated screen relay and not the timer relay?
So replacing that should be my first port of call?
Thanks
Post #942469 14th Feb 2022 4:26pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
My heated screen has stopped working.
When I press the heated screen button, the orange light only comes on for a second before switching off again.
…. I answered my own question, seems engine has to be running for it to stay on.
However my heated screen still doesn’t work. I have 12v to the purple cable on the left of the screen but no heat. So my guess is the screen is goosed. Maybe the big chip in the centre has something to do with it…
Post #974527 13th Dec 2022 11:44am
Martin
Site Admin
The orange light is feedback from the heated screen relay (light is parallel to the screen as in my comment above), rather than an indication that the screen itself is working or not working.
So if the orange light comes on and goes straight off, the relay is working, and is being controlled by the timer. It's just being turned off again by the timer.
This points at the timer, or the engine running signal wire.
The engine must be running for the timer to start running, otherwise you get exactly the behaviour you've experienced - on for a second or two then off again.
On a Puma this engine running signal comes from the instrument cluster.
Main question before going any further... are you trying this with the engine running?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #974540 13th Dec 2022 12:58pm
Martin
Site Admin
OK you edited whilst I was typing Laughing
Do you test for 12V across the screen or use a different earth point?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #974542 13th Dec 2022 12:59pm
Yannis
My multimeter ran out of batteries as I was trying to test the screen.
So when Amazon brings me more batteries tomorrow I will try that.
Post #974547 13th Dec 2022 1:38pm
