![]() | Home > Maintenance & Modifications > Winch solenoid location? |
Miffy has her's mounted next to the PAS reservoir and the wander lead connector is mounted on the blanked off wing vent.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Mine (TD5 90) is mounted on the nearside wing (UK).
This way it is high and out of the way of water and general road and off road muck. Good luck I also have a generic neoprene cover for the winch that i got off ebay, it does the job. |
Ah you remind me I need to replace the winch cover. The last one fell apart due to sun damage. But, I came to check the winch yesterday and the rope is a HUGE block of ice...
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 ![]() ![]() ![]() |
That might be a good shout thanks. Have you got any photos for reference? Cheers |
No problem. You'll have to zoom in to see the wander lead socket in the vent. It is close enough to be able to have the winch controller easily inside the vehicle when required. The solenoid pack is up and out of the way of most of the dirty water and road salt and it is not covering 1/3 of the intercooler...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Thanks that's really helpful. Mines a Puma but might be able to do something similar.
If you lift that blanked off wing vent there is quite a lot of room under there behind the headlight. Might be an out of the way place to put the solenoid with the wander lead socket close by.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2277 ![]() ![]() ![]() |
Mine is under said wing blank. Easy access, well protected.
