Home > Maintenance & Modifications > New Dynamic Damper setup from IRB |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
https://www.facebook.com/IRBdevelopments/p...S1ercEGFTl
Click image to enlarge Click image to enlarge Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
8th Dec 2022 2:23pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Thanks for the post Naks.... maybe I should spend more time on this forum (although will get Martin chasing me lol).
Steve - I can't disagree that it's an expensive bit of kit, but are a different league to even the Fox Adjustables. When powered off they go their stiffest setting, but chances of them failing on road is pretty slim. All fully sealed plugs (that I would also heatshrink seal), IP rated ECU plug etc. This is properhigh end kit - and used a lot of off road motorbikes as well as supercars. On the road you can simply press one of your presets - so you can have bumpy A road, sports mode, motorway etc etc. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
10th Dec 2022 4:20pm |
