Home > Technical > Winch wiring - how to route ?
Simonwood
Hi,
Installing a winch, front, and curious how you guys route the cables? Thru the grill, drill a hole thru the front bulk head, then under floor to battery box ?
Or under chassis ? (Carefully ) ? Then up to the battery box ?
Post #973840 7th Dec 2022 8:16pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
mine is along the chassis leg via the existing holes in the battery box. Been there several years and through deep water and thick mud and has never been a problem. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #973842 7th Dec 2022 8:41pm
htb2
Wales
Same as Dave when had 8274. Cables still there but have now changed to PTO Superwinch H12.
Post #973844 7th Dec 2022 8:45pm
Iā€™d also put it in split or non split convoluted tubing for extra protection where possible and will offer extra protection from impact and abrasion.
If you can find room. KEEP CALM AND Drill ON
šŸ‡¬šŸ‡§šŸ“󠁧󠁢󠁄󠁮󠁧ó æšŸ“󠁧󠁢󠁷󠁬󠁳ó æšŸ“󠁧󠁢󠁳󠁣󠁓ó æšŸ‡®šŸ‡ŖšŸ‡ŗšŸ‡øā›½ļøšŸ›¢ļøāš™ļøšŸ§°šŸ’Ŗ
Post #973859 7th Dec 2022 9:54pm
I used 75mm^2 (high-flex arc welding) cable for power and ground running along the chassis and under the grille panel. The power cable is run in a (non-split) convoluted sleeve, the ground is not. There is a manual isolator in the cab, as well as an Anderson connector which allows the winch to be powered from an external battery isolated from the vehicle battery or the vehicle to be jumpered to another for winching or starting.
Post #973879 8th Dec 2022 7:30am
geobloke
Pretty much the same as Blackwolf and others. Except that I have both a +ve and -ve cable that goes from the battery to the winch, no chassis earthing. This is as a consequence of the winch earthing through my old Defenders handbrake cable (which was engaged) when I had to ease a fellow off a rock. With the handbrake stuck on it was quite some time before I was mobile again. Since that time I have run directly back to the battery.
Post #973881 8th Dec 2022 8:37am
jst
on all mine with winches run two cables back to battery along top of passenger side chassis rail, under foot well, then into battery box, no sleeving and no problems on any of them. under the grill to battery at the front. put the +ve through an isolator then to battery +ve Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #973940 8th Dec 2022 2:34pm
