Home > General & Technical (L663) > Can l get the radio to stay on?
Page 2 of 2 <12
AndrewS
Apart from lighting the pavement up in the direction you are turning Wink 130's have feeling's as well you know Smile
Post #973532 5th Dec 2022 9:17pm
lightning
The pavement's already lit up like daylight from the monumentally bright LED headlights
lt's just pointless copycat tech because one manufacturer did it and everyone else followed suit. Fortunately the Jimny is largely devoid of such frippery.
Post #973533 5th Dec 2022 9:28pm
AndrewS
Not sure its copy cat as LR were first to introduce it years ago. 130's have feeling's as well you know Smile
Post #973534 5th Dec 2022 9:36pm
haymeister
Japan
I find the fog light illumination when turning does provide that bit extra illumination to the side in which I am turning.
As AndrewS mentions, it illuminates the ground which can be tricky with kerbs/low posts/ditches.
The main beams (which are poor IMHO) are not adaptive in the sense they do not turn when you turn the steering wheel (not referring to the adaptive function for high beams in the Matrix LED type)
The stereo only remaining on for a few minutes when the ignition is off is very annoying.
Modern cars and the power they consume I guess..... 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #973550 6th Dec 2022 12:23am
lightning
Well l guess there is some use for it then.
The headlights aren't as bright as the ones on our Jimny, those are incredible (for a small fairly cheap vehicle)
Definitely the best headlights l've used.
The worst were on my 1939 Morris 8, it was difficult to tell if they were actually on, in fact they had little tell tales on top of the lamp housings for that very reason.
Post #973560 6th Dec 2022 7:55am
WizzardPrang
After I've switched the engine off and gone to open the rear door to get my dog out, the radio switches itself on, even if I wasn't using it beforehand. Rolling with laughter Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #973594 6th Dec 2022 11:35am
mse
lightning wrote:
What's with the ridiculous "single fog light" illumination when you go round a corner? l can tell that my Defender does it, but it has no apparent use whatsoever
In dark lanes it works well tbf Mike
Post #973764 7th Dec 2022 8:30am
lightning
Well, my Defender did a software update yesterday and now, if you switch off the engine and stay in the vehicle, after a few minutes you get a message which says "vehicle will shut down in one minute"
And there's an option to "Delay"
Pressing "Delay" the radio stays on. Currently sat here for twenty minutes having my lunch and the radio is still on.
Maybe someone from Land Rover was reading my post about wanting the radio to stay on !!
Post #973924 8th Dec 2022 1:21pm
haymeister
Japan
How good. What software version are you on now?
It will say in your Pivi Pro, last row. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
Post #973932 8th Dec 2022 2:10pm
Page 2 of 2 <12
