Home > Puma (Tdci) > Transmission whine in 5th and 6th gear
Page 3 of 3 <123
It’s probably a bearing that’s in the depths somewhere or something like that.
I expect an inspection on the bench by a specialist would be able to identify it what it is that is doing it. WeWillWin🇬🇧🇺🇸
Post #973100 1st Dec 2022 6:33pm
dmbueno
United Kingdom 2002 Defender 90 300 Tdi SW Zambezi Silver
pedrocandrade wrote:
We finally got rid of the problem with another used transfer box. Gearbox was not the issue. It’s something inside the transfer box that we were not able to identify on inspection. The fact that it is audible only on 4th, 5th and 6th appears to be simply related to the input speed to the transfer box. We’ll keep this transfer box in the car and inspect the defective one once again to try to fix it.
I’m happy to see this saga come to a close. I hope this record will be helpful to others.
Hi Pedro - I have the exact same noise in my 2002 Defender with ~200k km. Did you find out what was wrong with the transfer case? I'm wondering if it can be easily repaired or better to get a reconditioned transfer box
Thanks!
Post #985265 12th Mar 2023 3:32pm
pedrocandrade
Brazil 2011 Defender 110 Puma 2.4 SW Epsom Green
Hi dmbueno, the problem was in the gears, not bearings. Three where replaced in the transfer case and the noise disappeared. However, I just heard that the noise is returning, so far only when you lift off the gas pedal. So, beware that the issue might not be easy to permanently fix. I don't know why.
Here are pictures of the gears that were replaced.
Post #990225 24th Apr 2023 8:57pm
dmbueno
Thank you for the reply - very informative.
I am not totally surprised to learn that it was the gears, since the noise is similar to a gearbox with straight cut gears. So it makes some sense. The gears that were probably not working that smoothly for whatever reason.
What is a little worrying is that he whine is coming back. That, along with your comment that when you replaced the transfer box with another one, you still had the noise. So it might be something structural in these transfer boxes - which is not great. But it is what it is, I guess.
Next question is, would this happen to all of the LT230s? It doesn't seem to be the case. So, what are the reasons why it's only some of them, and not others?
Hard to know I'm sure, but if someone has an idea I'm sure that a lot of us would appreciate knowing.
In my case, I am planning on installing a reconditioned TB. Probably more economical and more reliable at getting rid of the problem than a rebuild.
Post #990228 24th Apr 2023 9:15pm
Dinnu
I wonder if you would have been able to see any abnormality with prussian blue.
As regards transfer cases, there are 2 main ones (excluding the very early type). These are referred to as the LT230 and the LT230Q. Q stands for Quite, and they have the finer teeth (not on low gear). I also consider them as the less strong ones, but in part it could be caused by the fact that the Q were used on tdci engines Defenders. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #990256 25th Apr 2023 10:22am
Dinnu wrote:
... Q stands for Quite quiet ...
Fixed that for you. You have to love auto-spellcheckers, eh?
Post #990294 25th Apr 2023 3:23pm
TexasRover
I thought the LT230Q was specific for and normally fitted to the the Disco 2? For comfort.
I have a Series which had a terrible whine and found that changing the large needle bearings in the intermediate shaft/gear completely cured it. I had thought it was gear (meshing etc) related, but no pure bearing issue. Obviously this is NOT an LT 230 box
My current Td5 defender had a slight whine in the transfer case, quite easy to diagnose in my case because the whine was speed related and the same at 4th or 5th gear (at the same road speed). I could get my hand on a much older and higher mileage transfer case which I knew was quiet (had driven the car) and swapped it out one rainy day. The gears are now completely silent.
Not sure what makes these go noisy, I have not opened my removed transfer case, but I expect like the Series transfer case it I will find worn bearings. Maybe there are good and bad batches of bearings or maybe it is a lubrication issue.
Post #990301 25th Apr 2023 4:07pm
Dinnu
Cheers for that 🍺 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #990312 25th Apr 2023 6:04pm
TexasRover wrote:
I thought the LT230Q was specific for and normally fitted to the the Disco 2? For comfort. ...
It was introduced with and for the Disco2 but is not exclusive to the Disco2. It wasn't for comfort, it was supposedly quieter. My 2.4 Puma LT230 has the same ratio and internals as the Disco2, although interestingly the casings are not the same, and the reasons for this are very hard to understand.
Post #990315 25th Apr 2023 6:20pm
Dinnu
Here is a link to a very nice picture of the LT230 internals (less the center diff).
https://media.autoexpress.co.uk/image/priv...8/05_0.jpg
The gears to the left are from a Q box
The gears in the center are from earlier boxes.
The gears on the right were an Ashcroft development, and only few were made. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #990319 25th Apr 2023 7:09pm
Interesting that the Q gears in the photo do not have the centre PTO dog, as I recall both my Disco2 gearboxes and all three of my Puma gearboxes do have these.
Post #990334 25th Apr 2023 8:42pm
ashtrans
Site Sponsor
Most D2 boxes didn't have the PTO teeth, Dave
Post #990336 25th Apr 2023 8:58pm
Page 3 of 3 <123
