Home > Puma (Tdci) > B Pillar advice. |
The bolt doesn't look right - it shouldn't project like that - but yes, the trim does stop there. Darren
30th Nov 2022 10:23am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17339 |
The bolt is far too long, it should not extend out of the pillar. The trim does stop there and there is a hole with the bolt-ends visible, I found the a huge draft came out of mine so I covered them (neatly) with black duct tape to stop the gale.
30th Nov 2022 10:41am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 808 |
If you’ve bought a hinge kit. That bolt should be for the lower hinge.
You should match up the new bolts with the old ones. You’ll see the difference then between top and bottom hinge. 2008 2.4 110 Utility Station Wagon XS. |
30th Nov 2022 11:28am |
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 62 |
Hi,
Bloody hell, yes that makes sense. I will take them out one at a time and check. They are supposed to be a Landy expert as well! Chris |
30th Nov 2022 11:30am |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 183 |
CSI does some plugs to cover these holes in the B pillar
http://www.csiparts.co.uk/en-gb/products/b...110/120732 I don't have them though, so cannot comment further. /Mat |
30th Nov 2022 11:43am |
Damn, I'd forgotten about them, which is made worse by the fact that I bought a set a few years ago and haven't fitted them Darren
30th Nov 2022 11:47am |
Just above and below the hole are two M10 fixings.
I wonder what LR had them installed for? I am thinking of getting a plate made and using some plastic bolts? I think they must have thought of covering the hole and never got around to it? |
30th Nov 2022 12:02pm |
