Home > Puma (Tdci) > Shopping List.....
The Zee
Shopping List.....
Hypothetical: you work for a motor factors, and get an EPIC staff discount on parts, but you are leaving soon. Arrow What parts do you order and store/shelf for your Defender….
(No Genuine JLR parts, tyres or wheels, but Bosch, TRW, Nissens, Pierburg, Borg&Beck NGK/NTK, Lucas, Febi, BluePrint, LuK, FAG, INA and others are! Cool ) Zaid-M
www.DefencePhotos.com
Post #970831 11th Nov 2022 10:09pm
landy andy
All brake parts. Including master cylinder, and servo.
Obviously filters, and LOTS of the oils.
Starter, and alternator.
You could go for basic stuff, wheel bearings, wipers, serpentine belt, but they aren’t that expensive anyway.
Post #970832 11th Nov 2022 10:17pm
The Zee
First Order placed and recived :
2 x Lucas SQB 709 Headlight switches
1 x NTK Mass Airflow Sensor EPBMWT4-V003D
1 x BOSCH Manfold Pressuer Sensor 0 261 230 308
Bill : Less than £90 Shocked
Recomened Retail Price just under £196
Just how much mark-up / profit are JLR making on parts!
Next , Pads F&R (TRW) F&R wheel bearings (FAG) Wiper Blades (BOSCH) and EGR valve (Pierburg)
Anything else I should consider (Thanks Landy Andy for the tip so far) Zaid-M
Post #971376 16th Nov 2022 10:08pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I would also get:
EGR ( if not mapped)
VCV (Denso if available)
Post #971436 17th Nov 2022 2:22pm
I'd get a crateful of VCVs, not just one! Plus, if running stock a driveline, a couple of front differentials and a rear, and several sets of rear halfshafts and drive members. At least one set of injectors, a vacuum pump, about a dozen bonnet switches. Not forgetting a lot of absorbent cloths for dealing with water ingress.
Post #971474 17th Nov 2022 7:05pm
Co1
A few dozen intercooler hoses would last you 2 or 3 months as well!
Post #971477 17th Nov 2022 7:08pm
The Zee
Thanks all - Does my 2.2 have a VCV ?
If so can somebody please supply a part number and description...
Since we do keep Denso it can be Smile
Pierburg EGR in stock and booked out to me along with a set of pads and fitting kit, Wheel bearings on order (SKF).
A number of componets like injectors, alternators and starter motors are on exchange with a surcharge, the "used core" goes back to be refurbished /overhauled. For a lot of our customers this is not an issue since they are fitting the part within 24-48 hours so the used core comes back quite rapidly. Upwards of 20 calipers, 5 drive shafts form various makes and types per day! Zaid-M
Post #971489 17th Nov 2022 8:21pm
Ianh
Your 2.2 does have a vcv, however i have not read any posts about it failing, let alone failing as frequently as on the 2.4. So you could get one if cheap, but you may never need to use it.
Part 4 on the diagram https://www.lrworkshop.com/diagrams/land-r...mp_2.2tdci
I would add a Nissens coolant radiator to the list, they do fail and the nissens one is better and far cheaper than the LR one.
Good move on the pierburg egr as they actually make the Ford / LR one and include the gaskets.
Your intercooler will go at some point, but best once and for all replacement would be from BAS, so not worth buying a std crimped seam one.
How about ignition switch ?
You sure this is not your Christmas list to Santa Smile
Post #971494 17th Nov 2022 8:42pm
The bulb for illuminating the hazard switch. They fail and many people don't even know there's meant to be one.
Post #971497 17th Nov 2022 8:44pm
The Zee
Again many thanks all Thumbs Up
IanH - good shout with the Nissens - I'll see if its a stock item or order in. Intercooler - was thinking BAS or Alisport.
BlackWolf - funny you say that, replaced mine over the summer: they are tiny bulbes with a silly fixture/holder, have considered using a 12v 3mm red LED as a alternative to the bulb and cover.
Is this a Christmas list - only if the elves deliver before the 25th of this month, last day in the job. Zaid-M
Post #971500 17th Nov 2022 9:11pm
I’ll add another to the list that worked out well for me.
Borg & Beck Waterpump for the 2.4, interchangeable with the Transit 2.4.
Which also includes manifold and I’ve been really pleased with.
Cost about £80 at the time, vs LR @ £360 or there abouts.
Been running it for a good few years now and it’s been perfect, the LR one was leaking at the gasket. WeWillWin🇬🇧🇺🇸
Post #971503 17th Nov 2022 9:48pm
Here you go - 2.2 VCV:
 Darren
Post #971522 18th Nov 2022 12:01am
The Zee
It lloks like the Christmas elves turned up early:
1 x Pierburg EGR valve (+Gaskets inc)
4 x SKF wheel bearing kits
1 x TRW Frount pads (+Borg&Beck fitting kit)
1 x TRW Rear pads (+Borg&Beck fitting kit)
1 X Nissens Coolant Radiator
4 x Bosch 13" wiper blades
And an assortment of maintanance sprays, cleaners and microfiber cloths
Unfortunatley no Partridge in a Pear tree ! Laughing
Many thanks to all who advised or submited thoughts or ideas Bow down Zaid-M
Post #972613 27th Nov 2022 6:36pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Got to ask but why 4 wipers? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #972647 27th Nov 2022 9:48pm
The Zee
Since I have already 2 spare blades in the vehicle (I carry spare set, as backups) +4 gives me 2 complete sets (2 Fr + 1 R) = 6
Plus you rely on forward vision more than rear, the rear wiper on my defender is not the most effective device, yes it clears the water and muck, but not well. Motor, mechanisn, arm & blade are good, it's just poor performance. Zaid-M
Post #972654 27th Nov 2022 10:33pm
