![]() | Home > General & Technical (L663) > 90 Commercial safety issue UPDATE THERE IS A SWITCH!! |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 288 ![]() ![]() |
Scary! Where was the key? If you had it with you, you could have pressed the panic button for 3 seconds to sound the alarm. Also, if global opening and closing is enabled in vehicle settings pressing and holding the lock button would have opened all windows and sunroof. In the Commercial if the front door windows were open you’d have had some air at least.
The iGUIDE recommends not leaving the key in the vehicle, but would be better carried on your person anyway. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 ![]() ![]() |
I'm going to fit this for that very reason.
https://www.powerfuluk.com/rear-door-inter...-l663.html |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 ![]() ![]() |
It’s on the left hand D pillar.
![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2926 ![]() ![]() |
l'll check but l don't think mine has that fitted.
After l was released l looked everywhere for a button. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
I can think of worse places to be trapped
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1208 ![]() ![]() |
I definitely know the 110 does NOT have a rear door release button.
This was one of the very first mods I did on my 110. can't see LR would have deleted the switch on later manufacture... |
You can get out of the side doors on the 110.
No switch on mine, that's really bad and in my opinion a dangerous omission ![]() Click image to enlarge |
I stand corrected
![]() Whilst I understand my 110 has rear doors, I did it for convenience, as I will be sleeping in it. |
![]() Click image to enlarge well here is a close-up photo, which shows where j77 highlighted it, So is the wiring behind the side trim ? Does LR supply the switch within their 'Parts Department' ? All worth investigating, I think. |
Get on to the dealer, it should have one. 24MY 90 D250 HSE, Tasman Blue
Emailed the dealer this afternoon
l have been told that this switch is "no longer fitted to the Defender"
I consider this a serious safety issue, what if a child were to get in the back and close the door? l've contacted Land Rover and have had a response to say they are "looking into it" and will get back to me. |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 144 ![]() ![]() ![]() |
In the US Federal law dictates that an internal release handle coloured yellow should be fitted to the "trunk" or any compartment a human could become trapped in.
https://www.federalregister.gov/documents/...nk-release That Land-Rover has not done this suggests a failure of due diligence and lack of a robust risk-assessment process. Poor to unacceptable. |
Maybe a note to the HSE as for business use the vehicle could be considered to be a workplace. |
