Home > Maintenance & Modifications > Thermostat and rad bleed plug 300tdi |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
I am no expert and no mechanic so please bear that in mind when you read this response.
I use ptfe tape on many things that have a thread. I do it for two reasons - firstly to seal the thread and second to stop threads binding. You need to be careful when you take them out as the tape can come off and drop I to what you are taking them out of. I have seen one thread where they used a rad plug that had the bleed screw. I have never done this but when I saw it I thought what a good idea! |
26th Nov 2022 6:00pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1845 |
Once upon a time I used a brass radiator plu here (thermostat housing). Worked fine - and it would get you out of a jam temporarily - but when the time came for me to remove it, it had 'bonded' itself solidly to the thermostat housing and was a real pain to remove.
That said, even the plastic ones can be a pain to remove if they've been left in too long. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
26th Nov 2022 6:03pm |
Getting the plastic one out of mine was very difficult. I had to butcher it to remove it and I wouldn't fit another. I can't remember if the brass one had a rubber O ring or not?
If the brass ones also bind, the next time I remove it I will refit using ptfe tape. |
26th Nov 2022 6:34pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 763 |
Been using the X-Eng ones for getting on for 14-years now and find them ideal.
No 0-rings, I have always just used PTFE tape and never had an issue. Click image to enlarge ONE LIFE, GET IT! |
27th Nov 2022 11:26am |
