Home > Puma (Tdci) > 2.2tdci Traction warning light + grating sound |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17364 |
The noise is most likely the ABS modulator activating for the TC, Landrover's implementation always makes a hard-to-describe noise which could well fit your description. Assuming that there isn't a genuine need for the TC to kick in, it is most likely that there is a faulty sensor in one of the hubs, or for some reason the signal from one of the sensors is being degraded so that the TC thinks that one wheel is rolling at the wrong speed and is intervening.
I diagnostic tool is really the only way to get to the bottom of this and establish which sensor it is. The real fun starts, as I found once with my Disco2, when a faulty front wheel sensor tells the ECU that a wheel is spinning when it isn't, and the TC then jams one front brake hard on at speed. This is quite disconcerting! |
24th Nov 2022 1:18pm |
MattH268 Member Since: 01 Dec 2021 Location: Moray Posts: 66 |
Thank you for the reply, I very much hope never to have random braking at any kind of speed
Is there a recommended diagnostic tool to try to establish the sensor fault? It's not something I've had to consider before, but one might be pretty useful given that there are so many electronic systems on this vehicle. I'd normally avoid anything budget and opt for the middle or better but I've no idea. Maybe time for a little research. Many Thanks Matt 300tdi 90 CSW 2.2tdci 110 HCPU 1972 Series 3 88" Truck Cab |
24th Nov 2022 2:17pm |
The most popular (due to being a good balance of cost versus capability) are the Nanocom and the GAP IID Tool.
There are many threads on the subject of each, and it is hard to say (and incredibly subjective) whether either is "better" than the other, both have pros and cons. Other diagnostic tools are available, however the "generic" OBD tools usually don't really do enough LR-specific stuff to be much use. |
24th Nov 2022 3:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
Just go back a step first. It's been wet, pull all the loom connectors where the sensors attach. Clean them up and see if any progress made. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Nov 2022 5:04pm |
I'd seen these 2 options crop up quite a few times, what they do is still all way above my head at the moment. Plenty of reading to do
Justifying the expense of a diagnostic tool plus than my own capability to fix the issue, whatever it may be, will be the other consideration vs taking it to my mechanic and handing over the keys. 300tdi 90 CSW 2.2tdci 110 HCPU 1972 Series 3 88" Truck Cab |
24th Nov 2022 5:14pm |
I think it's about time I became more acquainted to my vehicle's electronics and sensors so hopefully it is a dry weekend to make a start. Thank you for your reply. M 300tdi 90 CSW 2.2tdci 110 HCPU 1972 Series 3 88" Truck Cab |
24th Nov 2022 5:23pm |
I'm just reading the Haynes Manual on the braking system and now I'm wondering if a low battery voltage which I know I had as I've just replaced the battery would account for the symptom. I will still investigate the connections and ponder further. 300tdi 90 CSW
24th Nov 2022 5:49pm |
