Home > Puma (Tdci) > no handbrake light
miker916
Scotland 2010 Defender 110 Puma 2.4 SW Alpine White
no handbrake light
Hi,
When i turn on the ignition, i dont have the handbrake warning light on and it dosent appear when the handbrake is on after the engine is started either, any ideas?
Mike[/img]
Post #970843 12th Nov 2022 1:08am
Dinnu
I would start with the switch itself, mounted on the side of the handbrake lever. You can see it after pulling off a bit the handbrake boot. Check that it is making a good contact to earth with the handbrake on. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #970849 12th Nov 2022 6:27am
miker916
Hi Dinnu,
Thank You, looks like i need to order a new switch, mines is missing its plunger completely.
Thanks
Mike
Post #971120 14th Nov 2022 3:31pm
miker916
My shiny new switch arrived so i thought id nip out and fit it, will only take 5 mins right?
Who at landrover thought it would be funny to put the screw heads on the inside of the handbrake?
On opening my shiny new switch i find out its backwards so it wont fit. Looks like you get left hand a right hand drive swictes. Could someone confirm the right hand drive part number for a handbrake switch please, this is what i mean by my new switch being 'backwards', new part on the left exiting broken part on the right:
Post #971877 21st Nov 2022 10:13am
Dinnu
Did you get part #2?
https://www.lrworkshop.com/diagrams/land-r...ever_52916 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #971884 21st Nov 2022 11:09am
miker916
i did, rimmerbros have just replied to my email saying only the left hand drive part is now available - FFS!
Post #971887 21st Nov 2022 11:27am
Dinnu
never removed the switch, but possible to mount 'up side down'? or the wire will foul? Or something else? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #971891 21st Nov 2022 12:05pm
miker916
the original connector was to long to fit the switch upside down so i ended up cutting it off and replacing it with a much shorter spade connector, all fitted and i now have a dashboard handbrake light Smile
Mike
Post #971896 21st Nov 2022 2:04pm
