Home > Wheels & Tyres > The Wolf steel wheel appreciation thread |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 564 |
Yes they will.
I have 255/85 KM3’s fitted to mine, picture is a few posts back for reference. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
14th Nov 2022 9:03pm |
Van Diesel Member Since: 12 Oct 2013 Location: Suffolk Posts: 177 |
Ah, perfect answer. Are yours original wolfs? Just wondered if they'd rub at all but should still be plenty of space. 21 Defender D300 H/Top
63 FFRR SDV8 86 90 Pick Up 3.9 V8 |
14th Nov 2022 9:31pm |
Hi, yes original LR Wolfs
They will rub on your radius arms, just need to adjust the steering stop bolts to suit. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
14th Nov 2022 9:36pm |
murph81 Member Since: 11 Sep 2022 Location: Ireland Posts: 63 |
I have a set of ex PSNI Tangi wolf steels, they are quite rusty.
I'd like to have them painted the same white as the roof on by Belize green 110. Whats the correct colour code? |
20th Nov 2022 9:38am |
They say if it sounds too good to be true it normally is, hence my hesitation on this advert.
However at £129 incl P&P for 4 x new genuine wolf wheels it seemed worth a punt. Description said a pallet had fallen over and some of the wheels were damaged. Nervously opened the boxes finding a scuff on the first 2 and a dented rim on the 3rd followed by a scuff on the last one. Pretty happy. I think the dent can be knocked out at a tyre place and as I'm changing the colour of them the scuffs don't matter. If the dented one was a write off it's still cheap for 3. First bit of luck I've had in a while. Click image to enlarge 21 Defender D300 H/Top 63 FFRR SDV8 86 90 Pick Up 3.9 V8 |
20th Nov 2022 8:06pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 512 |
Click image to enlarge Genuine Wolf's ( anr4583) with longer studs and 255 85 r16 Toyo Open Country MT's. The body is tarpaulin grey with limestone top and wheels. Last edited by MarkBrown on 15th Dec 2022 6:54am. Edited 1 time in total |
30th Nov 2022 8:42pm |
That looks perfect, was hoping to see those tyres on genuine wheels on a 110.
I'll be going for the same combo. I always like that size tyre on the Brooklyn Coachworks Defenders. |
30th Nov 2022 10:27pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
They do look perfect! I think they look better on the narrower rim, I think they're a little balloon looking on my ANR's. Might have to try a swap.... James
1st Dec 2022 8:47am |
Brooklyn coachworks do some lovely Land Rovers.
1st Dec 2022 7:17pm |
silvermilnec Member Since: 23 Nov 2021 Location: West Yorkshire Posts: 27 |
Wow what a long thread 😂
I’m looking to get some genuine wolfs. Does anyone know what stamps should be on each wheel? Much appreciated 👍 |
13th Dec 2022 8:28am |
ANR 4583
13th Dec 2022 8:27pm |
Thanks Mark!
Should there be something stamped between each lug, so 4 stamps on each wheel? Would you know the going rate for a set these days? Cheers Chris |
14th Dec 2022 9:02am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3475 |
Have a look at this site https://www.landroverexpedition.com/equipment/wolf-wheels/
As I am not the owner of the site, I cannot guarantee correctness, but good as a starting point. I have a set of aftermarket rims, and they seem to be well built and my guess is they are stronger than the axle itself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
14th Dec 2022 10:51am |
The number is stamped on the rim, its says anr4583 tubeless. There was a set on Ebay for £200, but they were powder coated black, which is fine, if you want black! About £300 plus for 4 is about the going rate, depending on condition. Good luck in your search. Thanks Mark
14th Dec 2022 10:52am |
