Home > General & Technical (L663) > Can I allow the boot to be opened from inside the car?
EdJ
Hi everyone.
Is there any way I can allow others to open the boot when I'm in the driver's seat? I'm finding that I have to stop the car and open the boot myself from the outside, rather than releasing the boot from inside the car.
Many thanks.
Post #970981 13th Nov 2022 4:14pm
LR Nuts
Post #971007 13th Nov 2022 6:13pm
whiterdesign
I’ve found that it is impossible to open the rear door whilst the engine is running even if the central locking unlock button has been pressed. Guess this is a security thing to stop anyone opening the door when stationary with the engine running. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #971048 13th Nov 2022 11:39pm
EdJ
Thanks for the replies. Yes, it's a shame there isn't an internal boot release button. Makes the dropping off or picking up of someone who needs to get something out or put into the boot very challenging.
Post #971073 14th Nov 2022 9:48am
LR Nuts
you can.
https://www.powerfuluk.com/rear-door-inter...-l663.html
Rear Door Internal Release Tap-in Loom for Land Rover Defender L663
This listing is for a rear door release tap-in loom for the Land Rover Defender L663.
This loom allows you to install an internal switch to open the rear door from the inside of the vehicle.
or you can buy the kit with a switch !
Locate the switch where ever you want, if you wire a second switch in parallel, one can be on the dash and one on the door itself.
Post #971097 14th Nov 2022 11:55am
J77
You can but only if it’s in park. 24MY 90 D250 HSE, Tasman Blue
Post #971101 14th Nov 2022 12:33pm
LR Nuts
as the driver, the vehicle should be in Park, to allow a passenger to alite then, if necessary, open the boot door.
Sometimes drivers need a Karnaugh Map to drive these vehicles.
Post #971105 14th Nov 2022 1:12pm
lightning
What's the score with the Commercial version? l've got a 90 on order, l assume that if for some reason you (or someone) shut the back door while you were in the load compartment, you'd be able to get out.
lf not, l can see that being potentially dangerous because unless someone let you out or you had a remote, you'd be stuck in there until the air ran out.
Post #971304 16th Nov 2022 10:34am
LR Nuts
you would need to clamber over the seats to get to one of the front doors to open it.
or fit the switch option by Powerful.
Post #971306 16th Nov 2022 10:37am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I believe the commercial Defenders have a switch in the rear to open the door from inside as standard, as in the 90 you couldn't crawl over the seats as the bulkhead is in the way. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #971341 16th Nov 2022 2:38pm
