Home > General & Technical (L663) > Work light?
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
Work light?
Any ideas on a good and low profile work light? 2021 Defender 110 D300 HSE
Post #971023 13th Nov 2022 8:54pm
gilesn
Hum - good question -
I would like the same -
Have seen several shapes & size (round, square, long-thin etc)
For me the actual light and the fitting of it is not the big issue.
For me the wiring & switching is the bigger worry.
So much talk about 'can bus' etc.
I come from the older days of just 'scotchlocking' in to the existing wire's with an inline fuse holder.
That doesn't seem to be the case now !!
Where I get confused is that the L663 runs 'can bus' - OK - but when I read up on 'lighting' the actual headlights use a 12 volt feed still?
All seem a bit mixed up to me.
Look forward to seeing if & how people have solved this - - -
Post #971062 14th Nov 2022 8:57am
Tim in Scotland
There are a couple of companies that make and sell additional/ upgraded interior lighting for the inside of the boot/ tailgate and they add a spur onto the wiring looming using the existing connector - have a look at PowerfulUK’s website and the fitting video or maybe even contact Simon as that is the sort of challenge I’m sure he would take up. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #971067 14th Nov 2022 10:19am
gilesn
Yes - powerfuluk do seem to have sveral options.
I need to look a little harder for the switched work light solution.
For me I want a rear extenral light fitting, yes picking up a power feed from somewhere in the back.
However I would like a switch somewhere in (inside) the back.
Yes - might well give Simon a call - - - -
Post #971069 14th Nov 2022 10:28am
Tim in Scotland
Here’s PowerfulUK’s offering
https://www.powerfuluk.com/vehicles/land-r...t-1pc.html Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #971075 14th Nov 2022 10:50am
Retroanaconda
Would be easy enough to run a feed from the battery under the seat I’d have thought, and mount a switch somewhere inside the rear door. The plate on the left where the suspension raise/lower buttons are would be a good spot - on mine there are some switch blanks there as it hasn’t got the deployable towbar.
Post #971078 14th Nov 2022 10:57am
LR Nuts
If the work lamp is just for the rear boot area, look at one of these. Again from powerful, but simple plug-n-play. I fitted one in my boot in 15mins.
https://www.powerfuluk.com/vehicles/land-r...-l663.html
Post #971099 14th Nov 2022 1:03pm
kjmeijer
I am looking for a work light on the outside of the car. The Rigid DC Scene Light looks good but I wondered I anyone had allready has a proven solution for a work light.
Rigid DC Scene Light:
Post #971107 14th Nov 2022 2:22pm
LR Nuts
I'm thinking of fitting a set of these to the roof rack
https://www.ebay.co.uk/itm/325378376541?ha...R6KygeyOYQ
Post #971121 14th Nov 2022 4:32pm
