Home > Off Topic > Trailer Tyres... |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2300 |
My Ifor GD105 could do with new tyres. It currently has 165 r13's on it.
I've seen horse boxes etc with chunky tyres on them and think this might be useful for a bit of extra height to avoid nose down towing. Anybody know a brand of such a trailer tyre? > 110 XS Double Cab |
9th Nov 2022 12:28pm |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
Would extra trailer height not make nose-down towing worse?
May have got wrong end of stick, Matt |
10th Nov 2022 7:06am |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
It would in theory, but that’s why you’d fit a Dixon Bate drop plate to adjust the tow ball to the trailer height. My trailer hitch sits pretty low as it’s designed that way for balance.
10th Nov 2022 7:27am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
I had nose up towing with my IW GD84 (single axle) even with a drop plate, My 10 x 5 IW tipper is perfect and my IW twin axle box was OK on the lowest setting.
I did the 70's Capri jack up solution and swapped the axle under the springs, changed bump stops etc and it tows perfectly. |
10th Nov 2022 12:13pm |
