![]() | Home > Puma (Tdci) > Strange one… |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 301 ![]() ![]() ![]() |
Was the downstream plastic manifold “T” fitting replaced?
Water in the diesel, ouch! |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Downstream T junction? It’s running too well for there to be water in the diesel but there’s water droplets & diesel sprayed under the bonnet!
The fuel lines above look a bit damp.
Is the plastic tee fitting leaking? ![]() Click image to enlarge |
That’s the fuel drain off pipe that’s been replaced twice ( part number LR029948LR) If it is that what would cause it to go twice? The truck runs too well for anything serious to be the cause that’s my thinking anyway.
landhank Member Since: 27 Oct 2021 Location: RLP Posts: 37 ![]() ![]() |
Good morning,
maybe one injector gives too much pressure in the back drain system. You should be able to see that with a leak oil test i think?! Cheers landhank |
Landhank I’m beginning to think along those lines. I’ve got the BAS OBD dongle & software so will see what the pressure is tomorrow. Does anyone know what a normal pressure should be?
The other thing is would the pressure limiting valve ( faulty) cause this ( I believe the 2.2 is located on the pump itself but the 2.4 is on the end of the rail) |
Not sure if you can check the back pressure of the injectors with an obd tool.
The pressure in the rail will be up to 1600bar i think and the pressure behind the injectors is nearly nothing… if only „a bit“ of the high pressure finds it way through a faulty injector (and if this is technically possible?!) that will blow up the leak oil line for sure. |
Hmmm things to think about. There’s no fault code & no lack of performance. If an injector we’re going down wouldn’t it affect performance & give a fault code?
