Home > Maintenance & Modifications > Which ignition and door barrel set?
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
My ignition will have to be replaced, so I might as well do the doors too.
I'll have to import.
I know genuine is best, but what is the quality of the Allmakes and Britpart sets?
Post #969141 28th Oct 2022 7:12am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
I have recently fitted a genuine set of three door lock barrels and a complete ignition barrel and was surprised by how reasonable the price was. I also purchased new anti theft bolts and the lower barrel strap too which are only a few pounds. With locks and the ignition barrel I decided aftermarket was probably too much of a risk and the price difference was small enough to make the decision easy.
The barrel set for Td5 2002 onwards is LR077438, I see the price has gone up nearly 20% since April
https://www.sp-4x4.com/LR077438_p/lr077438g.htm
The lower strap is QRG500010
The anti theft bolts are QRH100030
You will have to drill out the anti theft bolts and most likely destroy the lower strap in the process, hence getting the lower strap too.
Post #969153 28th Oct 2022 9:53am
rallysteve
I picked up that same genuine set via ebay for 49.99 last year so worth a check before you order.
Post #969154 28th Oct 2022 10:56am
jfh
Lots of the eBay sellers don't ship here.
Our postal service is also on-existent. It could take months to arrive.
On Lrdirect the genuine ones are double the price of Allmakes and they courier right to my door.
Making the choice more difficult.
Post #969158 28th Oct 2022 11:45am
