Home > Puma (Tdci) > puma mt82 gearbox stuck in first.. & Removing detents
Firemantom
Good evening,
I’ wonder if anyone can help… I’ve a 2009/10 puma hardtop with a mt82 gearbox. Stuck currently in first after a week on the driveway in gear.
I found a topic/thread showing how to sort potentially. Here: https://www.defender2.net/forum/post696217.html
I have followed instructions all the way to the detent section… and now I’m struggling getting these out. They aren’t what I was expecting…
Any idea how to remove?!
How to get this vehicle to select a gear other than 1st.?!
Help!
Post #968614 21st Oct 2022 11:02pm
landy andy
Post #968616 22nd Oct 2022 2:15am
The later style of detent isn't designed to be removed, and the only way to get them out is to drill a small hole in the top, screw a self-tapper in, then use a Molegrip or slide hammer to pull them out.
Ideally you should replace the detent but if you have to reuse them/it, put a couple of drops of oil down the hole you drilled then seal the hole with a blob of sealant on the outside only, don't push the sealant into the hole.
Post #968622 22nd Oct 2022 7:51am
Firemantom
Hoorah!
Thanks all for your help, the links to the other thread certainly helped. I’d found one but was with the older mushroom headed detents.
I did exactly that and screwed a self tapper in, sliding the rail worked and put it all back together before 0900 this morning! Actually oiled then left the screw in place if it happens again. It’s not blocking anything….
Thank you so much!
Post #968627 22nd Oct 2022 8:49am
Glad you're sorted. Every day with a Defender is an adventure! Thumbs Up
Post #968632 22nd Oct 2022 9:56am
jst
good result, had the same with mine. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #968636 22nd Oct 2022 10:36am
Nuddy
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Epsom Green
After some advice please. I’ve had the problem with the MT82 gearbox, stuck in first gear. I’ve removed the detent plug and put the gearbox back in neutral. Would you recommend putting the old plug back in, trying the gearbox by driving it, then strip it back down, remove the old plug and then fit the uprated one, or just fit the new uprated one straight away? Thanks
Post #979769 25th Jan 2023 5:21pm
