Home > Puma (Tdci) > puma mt82 gearbox stuck in first.. & Removing detents |
Firemantom Member Since: 21 Oct 2022 Location: Uk Posts: 2 |
Good evening,
I’ wonder if anyone can help… I’ve a 2009/10 puma hardtop with a mt82 gearbox. Stuck currently in first after a week on the driveway in gear. I found a topic/thread showing how to sort potentially. Here: https://www.defender2.net/forum/post696217.html I have followed instructions all the way to the detent section… and now I’m struggling getting these out. They aren’t what I was expecting… Any idea how to remove?! How to get this vehicle to select a gear other than 1st.?! Help! |
21st Oct 2022 11:02pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
22nd Oct 2022 2:15am |
Thanks all for your help, the links to the other thread certainly helped. I’d found one but was with the older mushroom headed detents.
I did exactly that and screwed a self tapper in, sliding the rail worked and put it all back together before 0900 this morning! Actually oiled then left the screw in place if it happens again. It’s not blocking anything…. Thank you so much! |
22nd Oct 2022 8:49am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
Glad you're sorted. Every day with a Defender is an adventure!
22nd Oct 2022 9:56am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8032 |
good result, had the same with mine. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Oct 2022 10:36am |
Nuddy Member Since: 25 Jan 2023 Location: Nottinghamshire Posts: 1 |
After some advice please. I’ve had the problem with the MT82 gearbox, stuck in first gear. I’ve removed the detent plug and put the gearbox back in neutral. Would you recommend putting the old plug back in, trying the gearbox by driving it, then strip it back down, remove the old plug and then fit the uprated one, or just fit the new uprated one straight away? Thanks
25th Jan 2023 5:21pm |
