Home > Maintenance & Modifications > Larger / add on Fuel Tank 2.4 Puma |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
I looked at options for our 90 too and concluded it is somewhat limited... if non-existent
in the end decided to KISS 20Lts = 100Miles Click image to enlarge I did like the possibility of utilising the space within the Spare Wheel (which I assume is reversed)... Click image to enlarge Click image to enlarge Although for us this is not straight forward... (projects Wheel and Can further back + additional weight on Carrier) Click image to enlarge So the Jerry Can is still the simple low cost route... SKIP https://www.defender2.net/forum/topic83242.html |
4th Mar 2022 11:18am |
Deflandman Member Since: 01 Jul 2021 Location: St. Paul's Bay Posts: 2 |
Hi, do you have any pictures you can share? Is the one you installed the DA 4546? |
20th Oct 2022 3:27am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Few versions are available - plenty of pictures via Google. Rgds.
Chris |
20th Oct 2022 11:34am |
Thug Member Since: 02 Aug 2022 Location: Johannesburg Posts: 20 |
I have a 40lt auxilary tank on my 90 with an extra filler cap next to the drivers door. An electric pump connects it to the main fuel tank inlet pipe.
Can't tell you who provided it as already installed when I purchased the 90. |
20th Oct 2022 2:56pm |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 71 |
I knocked up this bracket for 10L containers. 20L are too heavy to get on & off the roof. Maybe 10L containers are low enough for tollways?
Anodised aluminium & 316 stainless hardware. Click image to enlarge Click image to enlarge It's been over thousands of km of corrugated roads & no issues so far. Visitor - Freelander owner |
21st Oct 2022 8:32am |
That is very neat Darren
21st Oct 2022 9:28am |
Apart from 4 x 10L, we also have 2 x 5L in the second spare wheel on the roof.
The whole setup. (the chainsaw is not ours) Because they are a maximum of 10L you will actually get the fuel off the roof regularly as they are easy to handle. Visitor - Freelander owner |
21st Oct 2022 11:21am |
cool stuff
21st Oct 2022 4:04pm |
