Home > Maintenance & Modifications > Larger / add on Fuel Tank 2.4 Puma
Page 2 of 2 <12
I think D44 sells something similar, and will be experienced in fitting as well in house.
Myself I use two 20L Jerry cans strapped in, in the rear behind interior bulkhead.
Sometimes I only need one.
Iโ€™ve got a white one and a camo one.
Take disposable gloves and paper towels and always been not problem at all to me but not easy for everyone as they can also be considerably heavy.
Blackwolf on here I believe has mentioned this before, 20L has considerable weight to it and the can itโ€™s self. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #944514 3rd Mar 2022 10:14pm
X4SKP
I looked at options for our 90 too and concluded it is somewhat limited... if non-existent
in the end decided to KISS Exclamation
20Lts = 100Miles
I did like the possibility of utilising the space within the Spare Wheel (which I assume is reversed)...
Although for us this is not straight forward...
(projects Wheel and Can further back + additional weight on Carrier)
So the Jerry Can is still the simple low cost route... SKIP
Post #944548 4th Mar 2022 11:18am
Deflandman
Malta 2010 Defender 110 Puma 2.4 USW Orkney Grey
R1200GS wrote:
Yes, I have one on mine.
Gives about a 100mile extra range capacity.
Regards Dave
Hi,
do you have any pictures you can share? Is the one you installed the DA 4546?
Post #968373 20th Oct 2022 3:27am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Few versions are available - plenty of pictures via Google. Rgds.
Chris
Post #968430 20th Oct 2022 11:34am
Thug
South Africa 2009 Defender 90 Puma 2.4 CSW Indus Silver
I have a 40lt auxilary tank on my 90 with an extra filler cap next to the drivers door. An electric pump connects it to the main fuel tank inlet pipe.
Can't tell you who provided it as already installed when I purchased the 90.
Post #968448 20th Oct 2022 2:56pm
Lightwater
Australia
I knocked up this bracket for 10L containers. 20L are too heavy to get on & off the roof. Maybe 10L containers are low enough for tollways?
Anodised aluminium & 316 stainless hardware.
It's been over thousands of km of corrugated roads & no issues so far. Visitor - Freelander owner
Post #968508 21st Oct 2022 8:32am
That is very neat Thumbs Up Darren
Post #968515 21st Oct 2022 9:28am
Lightwater
Australia
Apart from 4 x 10L, we also have 2 x 5L in the second spare wheel on the roof.
The whole setup.
(the chainsaw is not ours)
Because they are a maximum of 10L you will actually get the fuel off the roof regularly as they are easy to handle. Visitor - Freelander owner
Post #968536 21st Oct 2022 11:21am
Deflandman
cool stuff
Post #968566 21st Oct 2022 4:04pm
Page 2 of 2 <12
