Home > Puma (Tdci) > MAF Sensor Fault Code?? |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Swim_Cap
I can't answer the question between a CAT Removal and if this is likely to affect the MAF Sensor... But it is tempting to think that yours may not be just a coincidence. I had a MIL / Warning Light at about six month intervals with a P1103 fault code when I first got my 90 (a 2010/11 2.4 tdci all Standard Mechanicals) I bought a ScangaugeII as a consequence of this. My fix on about the 3rd occasion was to Clean the MAF with a 'specialised' cleaner (lots of don't use just anything for this on-line.... WD40 for example ) I do this once a year, with No reoccurrence now for 5 years. Maybe worth a try as you watch and wait for potentially this to repeat itself. Click image to enlarge Click image to enlarge Click image to enlarge Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
21st Oct 2022 2:04pm |
Swim_Cap Member Since: 13 Oct 2019 Location: Cumbria Posts: 17 |
Hiya X4SKP,
Thank you so much for your response! I will give it a go (just ordered some cleaner) and let you know how I get on. Thanks again for your help |
22nd Oct 2022 3:58pm |
Hello Swim_Cap
Hope this works for you… just to add from reading up a bit around the P1103 fault code on a Puma, I think that the MIL / Engine Warning Light re-sets itself after around 6 Engine Cycles, I’ve seen variations on exactly how many and to what actually counts as an Engine Cycle (Duration / Rev Range). My first / second P1103 did ‘self cancel’, after around a week of daily use. On plugging in the Scangauge P1103 was the recorded Fault Code, which could be Cancelled (with the ignition / not engine on). Another ‘observation’ my local independent said to me very early on when I got my 90 to keep an eye on and swap out the Air Filter regularly… the ‘Puma likes to breathe’. Good luck SKIP https://www.defender2.net/forum/topic83242.html |
23rd Oct 2022 8:26am |
