Home > Puma (Tdci) > MAF Sensor Fault Code??
Swim_Cap
United Kingdom 2009 Defender 90 Puma 2.4 HT Zermatt Silver
Happy Friday everyone,
Just fitted a Demand Engineering down pipe and full sport’s exhaust system to my 2009 2.4 TDCI (yesterday) took it for a test drive and the engine light came on with the attached fault code! could this be linked to changing (removing) the Cat??
P1103-00 (EF) Mass air flow sensor in range but higher than expected. At 0mi
I cleared the fault and it hasn’t come back on yet…… 😬
Post #968533 21st Oct 2022 11:08am
X4SKP
Hello Swim_Cap
I can't answer the question between a CAT Removal and if this is likely to affect the MAF Sensor...
But it is tempting to think that yours may not be just a coincidence.
I had a MIL / Warning Light at about six month intervals with a P1103 fault code when I first got my 90
(a 2010/11 2.4 tdci all Standard Mechanicals)
I bought a ScangaugeII as a consequence of this.
My fix on about the 3rd occasion was to Clean the MAF with a 'specialised' cleaner
(lots of don't use just anything for this on-line.... WD40 for example Shocked )
I do this once a year, with No reoccurrence now for 5 years.
Maybe worth a try as you watch and wait for potentially this to repeat itself.
Good Luck... Thumbs Up SKIP
Post #968550 21st Oct 2022 2:04pm
Swim_Cap
Hiya X4SKP,
Thank you so much for your response! I will give it a go (just ordered some cleaner) and let you know how I get on.
Thanks again for your help Thumbs Up
Post #968652 22nd Oct 2022 3:58pm
X4SKP
Hello Swim_Cap
Hope this works for you… just to add from reading up a bit around the P1103 fault code on a Puma,
I think that the MIL / Engine Warning Light re-sets itself after around 6 Engine Cycles, I’ve seen variations on exactly how many and to what actually counts as an Engine Cycle (Duration / Rev Range).
My first / second P1103 did ‘self cancel’, after around a week of daily use. On plugging in the Scangauge P1103 was the recorded Fault Code, which could be Cancelled (with the ignition / not engine on).
Another ‘observation’ my local independent said to me very early on when I got my 90 to keep an eye on and swap out the Air Filter regularly… the ‘Puma likes to breathe’.
Good luck SKIP
Post #968711 23rd Oct 2022 8:26am
