Home > Technical > 3rd brake light
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
3rd brake light
Hi
I am at a complete loss!
My 3rd brake light hasnt been working for sometime. All other brake lights work fine
changed bulbs nothing, then i saw on a thread here about the casing wearing away the power strip so did the jump with a cable.
I now have 12v at all points to the holder, the holder and bulb have continuity and i have bought new bulbs.
It should work, but doesn't, what am i missing!
Please help before i question my sanity!
Post #968312 19th Oct 2022 2:36pm
rallysteve
Have you checked the cables in the convoluted rubber grommet/tube which lead to the door? Likely one or more is broken 02' 110 TD5 Double Cab Rebuild Thread
Post #968314 19th Oct 2022 2:52pm
Snowy90
Hi no i haven't but I'm getting 12v at the socket/bulb holder when the brake pedal is pressed.
Ill have a look though
Post #968315 19th Oct 2022 2:59pm
LR Nuts
Check the bulb holder earth point.
Where was the earth lead when you tested and got 12v ?
PS High level brake light is NOT a legal requirement hence will not fail an MOT, but yes its good practice to have it working.
Post #968329 19th Oct 2022 3:59pm
Snowy90
Hi
I just measured off the two connectors to the bulb holder.
Nothing until pedal depressed then 12v
Is there another earth closeby?
It just keeps coming up as an advisory and I will have bikes ina a rack so wanted to get it working.
Post #968331 19th Oct 2022 4:08pm
rallysteve
It is possible to still get 12v on a cable when open circuit but it not be able to provide any current when under load when a cable is damaged.
Try measuring the voltage across the bulb holder with the bulb in place. 02' 110 TD5 Double Cab Rebuild Thread
Post #968336 19th Oct 2022 5:25pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I had the same problem with no 3rd brake light.
The wiring goes through the heated rear window element,so if you have a break in any of the heater wires within the heated rear window the 3rd brake light won't work.
I bypassed the heated window by disconecting the feed wires to the heated rear window put in a wire from each side to the terminals on the 3rd light.
Hey presto.....3rd light works.
Marc.
Post #968348 19th Oct 2022 6:13pm
GuJa
Germany 2008 Defender 90 Puma 2.4 SW Tonga Green
The case of the 3rd brake light tends to chafe the electric lines. Remove the case and have a close look where the case and the rear screen come together.
Post #968356 19th Oct 2022 7:08pm
I thought that problem had been solved by 2008 when the heater element was re-designed to go around the brake light casing? Darren
Post #968361 19th Oct 2022 7:35pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
I had the same issue with my 110. Tested fine with 12v across the terminals in the bulb holder but no bulb would light. It's possibly that the strip in the window deteriorates and gives a very high resistance, it'll test ok with a meter but as soon as you draw a bit of current with a bulb you get no volts. I ran a short piece of wire from the spade connector at the bottom of the screen under the rubber seal to the bulb holder to fix the issue. You can barely see that I have had to do this.
Post #968363 19th Oct 2022 7:50pm
sharkey964
Thumbs Up
Post #968364 19th Oct 2022 8:15pm
sharkey964
Exactly what I said/did...
Post #968365 19th Oct 2022 8:17pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Same here just a few weeks ago. Multimeter showed 12v but obviously not enough getting through to light a bulb. Same solution, I meant it as temporary but it turned out very neat so will leave.
Post #968444 20th Oct 2022 2:24pm
Snowy90
Makes sense, i never use the heater screen as generally in the garage so not sure if its works properly.
Did you guys run two wires up the rubber? or just one? left or right as your facing it.
Post #968512 21st Oct 2022 8:58am
spudfan
Ireland
I ran two wires in the rubber seal and have stopped having issues. I once bridged the element with a piece of tin foil from a chocolate bar which worked until I ran the wires inside the rubber seal. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #968540 21st Oct 2022 11:49am
