Home > V8 > My V8 Swap (Toyota 1UZ-FE) |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 342 |
Seal still intact just leaking, theres also like a few mating faces there with the cover plate to the sump then block too. so, could have been that as well as. 4.0 V8 Defender 90
My Instagram |
26th Sep 2022 5:32am |
Tested the Clutch yesterday after sorting the PAS line and tidying a few bits up.
All went well as you can tell from the video. I reckon I'll let it run for a 5 or so minutes and check oil levels since I've got a cooler on the R380. Other than that all I've got left to do is fix the radiator in place and a few small tasks then I should be ready for a test drive, albeit without a bonnet. 4.0 V8 Defender 90 My Instagram |
10th Oct 2022 7:18am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 489 |
Sounding nice
10th Oct 2022 11:38am |
Cheers Linds 4.0 V8 Defender 90
My Instagram |
11th Oct 2022 5:56am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
Sounds awesome more like! |
11th Oct 2022 5:57am |
Had my first test drive in the build last night and when manoeuvring it through the unit and out I noticed the inside rear wheel was hopping/ slipping.
Will this be down the nature of the torque biasing diff in the TC or do I have the diff locked without me knowing? Other than that everything went well. Looking forward to assembling everything back together now. 4.0 V8 Defender 90 My Instagram |
Cheers, I'll upload a couple short clips later 4.0 V8 Defender 90 My Instagram |
11th Oct 2022 5:58am |
Revs: https://youtube.com/shorts/GCLaceVPVxU?feature=share
Driving Clip: https://youtube.com/shorts/IN6bP76wwf0?feature=share 4.0 V8 Defender 90 My Instagram |
11th Oct 2022 7:42am |
Dtes Member Since: 01 May 2022 Location: Staffordshire Posts: 10 |
They never normally skip with an ATB in the transfer box |
16th Oct 2022 11:00am |
Ok Cheers DT 4.0 V8 Defender 90
My Instagram |
16th Oct 2022 2:47pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
As we say in Aussie, "Nothing like a V8"!
Pickles. |
16th Oct 2022 10:18pm |
Its the way forward 4.0 V8 Defender 90
My Instagram |
17th Oct 2022 8:00am |
Timbo Member Since: 15 Jun 2021 Location: west mids Posts: 136 |
Sounds beautiful Mucker. Citroen 2CV. (Written off)
66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
29th Oct 2022 8:07pm |
Little Clip of the Car on the road:
https://www.youtube.com/shorts/wjmHVzi_MM8 I failed to sort the oil leek on the back of the engine so its coming out again... After that I'll be ready to have a tune and dyno run maybe which will be interesting. 4.0 V8 Defender 90 My Instagram |
13th Nov 2022 1:03pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3686 |
Sounding very smart indeed!
13th Nov 2022 1:19pm |
