Home > In Car Electronics > Defender switch panel
termohe
Belgium 2004 Defender 90 Td5 HT Alpine White
I have a TD5 with a non standard dashboard and all gauges and switches fitted on flat panels.
As I am reorganising the middle part, I want to move the standard switches from the top to the left side by using the switch panel MUD-0093 from Mudstuff, however that panel is not flat as it is intended for a Puma.
Is there an alternative on the market?
Post #967537 13th Oct 2022 12:32pm
Quote:
These switch mounts snap into an outer frame that has been moulded to follow the compound curve of the Puma dashboard ‘cheek’.
The Mud panel comprises two parts - the switch mount, which is flat, and then the outer bezel that is shaped to fit a Puma dash. It would be worth checking with them before buying but it looks like you could just use the switch mount on its own in a flat panel. You may have to drill some holes for screws or perhaps glue the mount to your dash panel. Darren
Post #967635 14th Oct 2022 9:40am
DSC-off
The switch panel from a Discovery2 may do what you want, but it's only got 6 switches and the Hazard Warning switch is a different size.
Post #967637 14th Oct 2022 10:33am
DSC-off
Post #967638 14th Oct 2022 10:42am
