Home > Puma (Tdci) > OBD II Scanner Bluetooth - Defender Puma 2007
hjellemorten
Norway 2007 Defender 90 Puma 2.4 HT Rimini Red
Looking for an OBD II Bluetooth scanner, compatable with IOS, for my Defender Puma 2007 2,4.
Any recommendations?
Also, any with experience with the Veepeak OBDCheck BLE Bluetooth OBD II Scanner Auto Diagnostic Scan Tool for iOS?
Post #966915 6th Oct 2022 6:27pm
Ianh
Have a look at the OBD2Link MX+ https://www.obdlink.com/products/obdlink-mxp/
I have had the LX version for several years and gives great performance, but would purchase the MX+ now it’s available.
They are a reputable company, provide their own software plus support all the other apps, have secure Bluetooth, and will power down when ignition off.
I would not connect cheap Chinese EML327 readers to expensive vehicle ECU’s.
Ps. If you do go down this route buy from an authorised seller, else you may end up with a fake one.
Post #966943 6th Oct 2022 8:53pm
hjellemorten
Thanks, any advantage going for the iiDTool BT https://www.gap-diagnostic.com/products/iidtool/ over the OBD2 Link MX+ for a Defender Puma 2007?
Post #972269 24th Nov 2022 7:24pm
Ianh
The IIDTool is far superior, I would say the best non dealer diagnostics tool you can get for a defender.
Noting each licence for use is locked to a specific individual vehicle via its VIN. Hence it is expensive but if you only want to use the tool on your own vehicle I would say it’s a perfect choice for you.
The OBDLink mx+ is a great generic code reader for any OBD2 compliant vehicle and you can use it on as many vehicles as you like. However its capabilities do not come close to the specific defender functions the IIDTool has.
Post #972296 24th Nov 2022 10:50pm
bodstruck
IID is really good. Keep an eye out and you can pick them up second hand for about £300. Added bonus is that you can also add and remove BAS remaps using it if you decide to go that route. Thumbs Up
Post #972342 25th Nov 2022 12:18pm
