Home > Technical > 3.5L V8 fuel pump |
Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171 |
Hi all,
Just a quick question, I have a 1984 3.5L V8 petrol 110. When I put the key in and turn it I need to let the fuel pump prime up a bit before I start it . I can hear a rapid ticking that then goes to a slower ticking. It then almost always starts first time. When I am stopped at an intersection I can still hear the tick on the fuel pump. My question is.... is this normal? Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
28th Oct 2011 12:53am |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
My v8 is so loud with the free-flow exhuast,I cant hear anything. It's fuel injected,and can here the pump priming when starting.With the SU carbs the pump was too quiet to here.The ticking may be normal as the pump works fulltime when engine is running. Puma 110 SW
90 V8 SOFT TOP |
28th Oct 2011 1:51am |
Yeah, it's pretty normal. My old Stage 1 V8 used to do exactly the same thing. Fuel pumps of that era operate around what is basically a set of points and the ticking is them making and breaking contact. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
28th Oct 2011 7:20am |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
another vote for normal
28th Oct 2011 8:05am |
THANKS for the feedback, nothing was really wrong but there are no many new noises in this "new" 1984 truck.....
I have the carbs not EFI - I think they are SU (with the two top hat type top cover on the carbs) Ill just keep putting along.... Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
29th Oct 2011 12:34am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
normal...i miss my v8 though Mike
30th Oct 2011 5:21pm |
