Home > Puma (Tdci) > Diff axle pinion oil seal for puma
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Planning to go on a safari this week end so wanted to have a check up, saw oil is leaking from the diff axle pinion seal area so suspecting the bad diff axle pinion oil seal both front and rear. Found two part numbers FTC5258 and FTC4851 with microcat but do not know the right one for puma. When inquired the local dealer, they also confused.
If anybody knows the correct part number please post. Cheers.! Very Happy
Post #96605 27th Oct 2011 5:29pm
MK
If you have the wolf-P38-type then FTC4851 Puma 110" SW
Post #96671 27th Oct 2011 9:40pm
dilukabey
[quote="MK"]If you have the wolf-P38-type then FTC4851[/quote]
Many thanks for info MK. Hope FTC4851 will fix mine.!
Post #96690 28th Oct 2011 2:27am
