- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
dilukabey
Diff axle pinion oil seal for puma | |
Planning to go on a safari this week end so wanted to have a check up, saw oil is leaking from the diff axle pinion seal area so suspecting the bad diff axle pinion oil seal both front and rear. Found two part numbers FTC5258 and FTC4851 with microcat but do not know the right one for puma. When inquired the local dealer, they also confused.
If anybody knows the correct part number please post. Cheers.!
27th Oct 2011 6:29pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
