Home > In Car Electronics > Wing Antenna |
A familiar tale...
I confess that I gave up on replacing external aerials and opted for an internal one situated up in one of the roof lights. Works a treat and I have not had to replace an aerial in 8 or 10 years. |
30th Sep 2022 1:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17507 |
No, the cable is usually integral with the aerial. You can however use the old one to pull a cord through and the cord to pull the new one back.
30th Sep 2022 2:01pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
I don’t extend my telescopic wing antenna at all and still get a superb radio reception. When you do resolve/replace it, it might be worth a test in the lowered position Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
30th Sep 2022 2:04pm |
churchy Member Since: 28 Jul 2011 Location: UK Posts: 237 |
Thanks all - looks like a full replacement then. The annoying thing was it was unextended when said pigeon took offence to it! Folded it flat against the wing so no way of avoiding the expected snap when I needed to move it back off the wing!
30th Sep 2022 2:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20540 |
Worth considering a Naka DAB one, then you’ll never have that issue nor will you have to manually extend it again. No Guts, No Glory.
30th Sep 2022 5:47pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
But then you lose your automatic roof height sensor
Having said that, the Naka DAB aerial is rather good 👍 |
30th Sep 2022 6:08pm |
