Home > Technical > LED Headlight Upgrade not working |
Check fuse 23 and 25 in the main dash fuse box. On a Defender the headlights are fused separately. Both should be 10amp fuses.
Edit: https://www.lrworkshop.com/electrics/defen...nd-headers |
24th Jan 2022 10:47am |
Coops Member Since: 20 Jan 2022 Location: Cambridgeshire Posts: 16 |
Thanks geobloke...I did check the fuses and they are good....sorry should have added that
24th Jan 2022 12:21pm |
Do you have power at those fuses?
24th Jan 2022 12:22pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5788 |
To be clear. You say “There is the relay delete thing in place (big pink one) above fuses.” Is it a relay delete, or is it the dim dip bypass. I didn’t think the bypass was pink. Pink was the working relay.
24th Jan 2022 1:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
It is likely the dim dip that needs disabling, this was a headache that I had. KEEP CALM AND Drill ON
24th Jan 2022 7:48pm |
Thanks Geobloke. I did some more testing then realised I was testing the wrong slots in the fuse box. I basically been looking at the fuse box upside down! When I pulled the right fuses at least one was blown put new ones in and everything now working! I both happy and really annoyed with myself for making such a school boy error…and I spent £70 I did need to on new switches.
Landy Andy…yes I meant the bypass it’s the YWZ 10003. Thanks everyone for making me recheck the more obvious stuff. |
24th Jan 2022 9:39pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10853 |
Good that you got it all fixed and working now and you have some good spares now Clayton.
24th Jan 2022 9:46pm |
mikeyo5ft Member Since: 19 Sep 2022 Location: Wales Posts: 3 |
Hello,
Did you pass the MOT with the halo wired into the side lights? I’ve got a set and just trying to fact find before fitting! Thanks |
19th Sep 2022 8:37am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
I’ve had the halos wired into the sidelights/markers for quite few years now, and whilst I did initially think it might not get past the MOT Tester, it hasn’t been an issue.
That said, I’ve now probably jinxed it… |
19th Sep 2022 9:51am |
Ah ok, thanks for letting me know. I wasn’t sure whether to wire halos into side lights or spend a bit more time and wire into the ign!
19th Sep 2022 4:12pm |
Although it probably shouldn’t be the case, we all have very different experiences of MOT Inspectors and MOT tests.
I appear to have a decent MOT Inspector who understands and likes Land Rovers. I’m not suggesting for one moment that he would apply too much discretion with regard to an issue affecting safety, but he does appear to apply common sense. Having said all that, he’s never really commented on the LED headlamps with the halo connected to the sidelights/markers, and they’ve been fitted for a few years. He does often tell me my truck is too clean! |
19th Sep 2022 4:37pm |
Thank you, I think I will connect mine in the same manner, I was concerned that the Wipac halos might be a bit too bright at night but if others are getting on ok with them will follow suit 👍
19th Sep 2022 5:36pm |
DICKO1995 Member Since: 02 Feb 2024 Location: High Peak Posts: 10 |
Click image to enlarge Hi, First post on here. Go easy. I’m having a nightmare with fitting Wipac led headlights, should be plug and play but not that simple (for me anyway) So my problem is that I have power to the headlights but only seem to have a low beam. With one push forward on the stalk the low beam comes on, when pressing the stalk forward again nothing changes, as if the main driving beam is not working. The full beam/flash is working and so are the DRL’s which are wired to the led sidelights. I’ll attach a photo of the Wipac fitting instructions. The main beam does work when the brown wire (main beam) and the green wire (dipped) are touching each other with the earth plugged into the connector. So i know that the main beam does actually work but once the wires are put into the connector and connected to the car I only have a small beam of light for both clicks of the stalk. Any help on this would be great. Could be me being stupid Cheers |
2nd Feb 2024 9:53am |
