Home > My Defender > hanks Double Cab
Page 16 of 22 <123 ... 151617 ... 202122>
hank
Look forward to seeing yours but for me it doesn’t make sense whilst the 2.4 runs well. Maybe one day if it dies a death.
NC500 looks great! Just need a second mortgage cover the fuel Laughing > 110 XS Double Cab
Post #953391 23rd May 2022 8:39pm
Welshsurferdude
Wales
N57 does 30+ mpg on a 8hp apparently
there you go! Laughing 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #953392 23rd May 2022 8:40pm
hank
Injector cover has been cracked since I've owned the Defender which bugged me, but not enough to pay £55 for a new one. Recently picked up a genuine replacement from ebay
 > 110 XS Double Cab
Post #955610 15th Jun 2022 5:10pm
CarMan
Result, assuming it was cheaper Thumbs Up
Post #955614 15th Jun 2022 5:36pm
hank
Back in April Shocked my blower began to work only on speed 3 - suspected blower resistor pack failure.
I ordered a new JLR part 11th April but by mid June it was still on backorder so I cancelled and went for an OEM replacement.
New part arrived within two days and I fitted it today - fiddly but ten mins later I now have blowers on speed 1, 2 and 3 again Thumbs Up
New OEM part on the left, original one on the right
 > 110 XS Double Cab
Post #956103 21st Jun 2022 11:29am
hank
Sailed through another MOT this morning. Did have one advisory... "Oil leak, but not excessive"
I think this might be a weepy power steering reservoir hose - will investigate. The MOT tester did add "show me a Defender without an oil leak" Laughing > 110 XS Double Cab
Post #956810 29th Jun 2022 9:08am
hank
Fitted a new clutch switch which has cured the revs hanging between gear changes
Space is tight in there so I cut the ring off the old switch which allows you to remove the electrical connector and get a grip on the switch body to rotate it out with grips whilst holding the adapter fitting with a spanner to prevent it from unscrewing from the master cylinder
JLR switch
Cut the outer ring off the old switch
This is what is left and can be turned out with grips
 > 110 XS Double Cab
Post #960586 4th Aug 2022 8:16pm
hank
New turbo is here. Will get it fitted when I return from holiday. The VNT vanes have gone stiff on mine and it was only around £80 more for a brand new turbo rather than refurbishing the old one
 > 110 XS Double Cab
Post #964393 8th Sep 2022 11:38am
90 Dreamer
when changing your clutch switch did you loose any fluid / have to re-bleed the clutch or does it have no hydraulic connection??
Post #965106 15th Sep 2022 10:44am
HardCharger
hank wrote:
Side tube seal fitted
Slider/sill interface without the seal
Slider/sill interface with the seal
I'd like more details on the slider/sill seal. I also have this gap and would like it sealed up for a neater look like you Thumbs Up
Is it one of those hollow D seals with the adhesive on it? Is it possible to stick it on with the rock and tree sliders in place?
Post #965423 19th Sep 2022 2:42am
hank
After unscrewing the old switch I filled the port with fluid in a syringe then screwed in the switch. The excess fluid was displaced and no bleeding required. > 110 XS Double Cab
Post #965528 20th Sep 2022 1:16pm
hank
hank wrote:
I got it on ebay. 3m will do both sides Thumbs Up
https://www.ebay.co.uk/itm/324138668389
With regard to the tree slider seals, see above Thumbs Up > 110 XS Double Cab
Post #965529 20th Sep 2022 1:28pm
hank
New turbo is on. A fiddly job to say the least.
Wasted far too much time trying to reconnect the oil drain to the under side of the turbo flange in situ until finally deciding to pull the oil drain from the engine block, connect the oil drain to the turbo on the bench then drop the lot into place in one piece. Reconnect the oil drain to the block and job done. Would recommend this approach to others.
Fitted new gaskets throughout:
- New head to exhaust manifold gasket
- New exhaust manifold to EGR valve gasket
- New Exhaust manifold to turbo gasket
- New turbo to downpipe gasket
Initial thoughts are that it comes on boost lower in the rev range and more aggressively but perhaps doesn't boost as hard higher in the revs - think that's a good thing though as diesel's should make power/be driven lower in the rev range
Couple of pics but I ran out of light so they aren't the best.
 > 110 XS Double Cab
Post #966203 28th Sep 2022 7:52pm
Do you know the part number for the manifold to EGR cooler gasket, please? I was fooled by the manual which says that there is no gasket fitted to this joint when I swapped manifolds yesterday but then spotted the old one on the ground. Sad
I'm having trouble finding it in LRcat.
Post #966223 29th Sep 2022 6:20am
rallysteve
https://www.lrworkshop.com/diagrams/land-r...tion_45016
Blackwolf, is it not number 3 on here?
Post #966229 29th Sep 2022 7:38am
