![]() | Home > My Defender > hanks Double Cab |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2317 ![]() ![]() ![]() |
Look forward to seeing yours but for me it doesn’t make sense whilst the 2.4 runs well. Maybe one day if it dies a death.
NC500 looks great! Just need a second mortgage cover the fuel ![]() |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2447 ![]() ![]() |
N57 does 30+ mpg on a 8hp apparently
there you go! ![]() 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
Injector cover has been cracked since I've owned the Defender which bugged me, but not enough to pay £55 for a new one. Recently picked up a genuine replacement from ebay
![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1876 ![]() ![]() |
Result, assuming it was cheaper
Back in April
![]() I ordered a new JLR part 11th April but by mid June it was still on backorder so I cancelled and went for an OEM replacement. New part arrived within two days and I fitted it today - fiddly but ten mins later I now have blowers on speed 1, 2 and 3 again ![]() New OEM part on the left, original one on the right ![]() Click image to enlarge > 110 XS Double Cab |
Sailed through another MOT this morning. Did have one advisory... "Oil leak, but not excessive"
I think this might be a weepy power steering reservoir hose - will investigate. The MOT tester did add "show me a Defender without an oil leak" ![]() |
Fitted a new clutch switch which has cured the revs hanging between gear changes
Space is tight in there so I cut the ring off the old switch which allows you to remove the electrical connector and get a grip on the switch body to rotate it out with grips whilst holding the adapter fitting with a spanner to prevent it from unscrewing from the master cylinder JLR switch ![]() Click image to enlarge Cut the outer ring off the old switch ![]() Click image to enlarge This is what is left and can be turned out with grips ![]() Click image to enlarge > 110 XS Double Cab |
New turbo is here. Will get it fitted when I return from holiday. The VNT vanes have gone stiff on mine and it was only around £80 more for a brand new turbo rather than refurbishing the old one
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 751 ![]() ![]() ![]() |
I'd like more details on the slider/sill seal. I also have this gap and would like it sealed up for a neater look like you ![]() Is it one of those hollow D seals with the adhesive on it? Is it possible to stick it on with the rock and tree sliders in place? |
After unscrewing the old switch I filled the port with fluid in a syringe then screwed in the switch. The excess fluid was displaced and no bleeding required. > 110 XS Double Cab |
With regard to the tree slider seals, see above ![]() |
New turbo is on. A fiddly job to say the least.
Wasted far too much time trying to reconnect the oil drain to the under side of the turbo flange in situ until finally deciding to pull the oil drain from the engine block, connect the oil drain to the turbo on the bench then drop the lot into place in one piece. Reconnect the oil drain to the block and job done. Would recommend this approach to others. Fitted new gaskets throughout: - New head to exhaust manifold gasket - New exhaust manifold to EGR valve gasket - New Exhaust manifold to turbo gasket - New turbo to downpipe gasket Initial thoughts are that it comes on boost lower in the rev range and more aggressively but perhaps doesn't boost as hard higher in the revs - think that's a good thing though as diesel's should make power/be driven lower in the rev range Couple of pics but I ran out of light so they aren't the best. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17619 ![]() ![]() ![]() |
Do you know the part number for the manifold to EGR cooler gasket, please? I was fooled by the manual which says that there is no gasket fitted to this joint when I swapped manifolds yesterday but then spotted the old one on the ground.
![]() I'm having trouble finding it in LRcat. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
https://www.lrworkshop.com/diagrams/land-r...tion_45016
Blackwolf, is it not number 3 on here? Steve 02' 110 TD5 Double Cab Rebuild Thread |
