Home > 130 > Transferbox lt230 problem
Rodo68
Chile 2009 Defender 130 Puma 2.4 HCPU Stornoway Grey
Hello I have problem with my def. It turns out that when I release the clutch I feel a hoarse buzz, check the sound and it seems to be between the gearbox and the transfer case.
In addition to the usual clunk that I thought was the differential.
the sound increases when I shift from 3rd gear to 4th gear.
Post #965405 18th Sep 2022 3:45pm
geobloke
The hoarse buzz is probably a main or support bearing failing. When they do they become pitted and noisy.
It could be either the LT230 or the R380/LT77 and the only real way to tell is to drop the gearboxes and inspect them.
Incidentally, my experience is that within 200 miles of this noise the bearing failed at 70mph and grenade'd 5th causing massive internal damage. Be careful and get it checked over. If you decide one or other of the gearboxes need an overhaul it is a very rewarding DIY job to do Thumbs Up
Post #965410 18th Sep 2022 5:58pm
OP appears to have a Puma, so an MT82 main box. If the noise was associated with a loss of drive I'd say output adaptor shaft coupling, but there are so many things it could be it's almost impossible to diagnose remotely.
Post #965416 18th Sep 2022 7:41pm
ashtrans
Site Sponsor
the MT82's have an issue where the spigot bearings collapse and chew the end of the input shaft, this would be noisy when you dip the clutch, Dave
Post #971929 21st Nov 2022 7:25pm
