Home > Technical > Death wobble
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Death wobble
I seem to be suffering with a bit of a death wobble on my Puma - its an 2009 model with around 53k on the clock. Recently replaced shockers all around, but there were no issues following that.
The problem mainly seems to be differing road surfaces, if the road surface is rough, the wobble is more pronounced. Also sometimes on motorways around 60 - 70, the steering wheel seems to vibrate and wobble a little.
New tyres fitted last year and wheels all balanced OK.
Could it be the steering damper? or something much more expensive......... Sad Euro-Leafing to infinity and beyond.....
Post #964904 13th Sep 2022 6:03pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Death Wobble in a Defender…. You need to get a motorbike to experience that properly😉 Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #964907 13th Sep 2022 6:30pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Start cheap.
Check for worn bushes, check for something loose.
Then work your way up. 👍🏻 2002 td5 90 county hardtop
Post #964908 13th Sep 2022 6:30pm
Leamreject
Also do a four point wheel swap just as a precaution because if you have a slightly buckled wheel it could change the dimension of the problem Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #964910 13th Sep 2022 6:37pm
Ianh
Along with bushes check the A frame ball joint atop the rear axle.
Post #964922 13th Sep 2022 7:48pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Agree with this - first change front wheels for back. Easy to do and costs nowt!
Post #964941 13th Sep 2022 10:59pm
Mo Murphy
Panhard rod bushes if it's a violent fast judder or swivel preload.
50 Shades of Pennine Grey
Post #964951 14th Sep 2022 5:54am
bear100
Have you fitted wheel spacers at all? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #964953 14th Sep 2022 6:21am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Swivel pin preload.
Post #965008 14th Sep 2022 1:38pm
spudfan
Ireland
If the wheels were balanced some of the balancing weights could have come off. Get the front ones at least checked to see if they need balanced. It's an inexpensive move that could solve your problem. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #965024 14th Sep 2022 5:01pm
strang
Nope Euro-Leafing to infinity and beyond.....
Post #965029 14th Sep 2022 6:27pm
Procta
i would do this 1st, i suspected i had the same thing, so me and my dad put the car up on the jack and had a go at moving the wheels for any play etc. We couldn't find anything at all. Went down to my local tyre garage and got the front wheels balanced, both needed re balancing, the driver side was well out.
by 100 gram Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #965072 15th Sep 2022 4:33am
bear100
some wheel spacers are tight on some alloys and can catch when putting the wheel back on 2023 Defender L663 V8
Post #965078 15th Sep 2022 6:29am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
My series 109 did that around 50mph it was horrendous, swapped the wheels around from front to back and it went away. 1953 80"
1987 mini city e
2011 90"
Post #965181 15th Sep 2022 8:45pm
strang
Just an update - I had the wheels checked for balance and they were fine. I had also developed a rattle which sounded like brake pads, but still rattled on rough ground whilst braking. Further examination has revealed that the lower bushes on the rear shocks are shot - so that is causing the rattle, hopefully once replaced it will cure the steering issue too. Euro-Leafing to infinity and beyond.....
Post #965541 20th Sep 2022 3:04pm
