- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
spudfan
Glad it was something simple and easily sorted. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
21st Sep 2022 1:20pm |
Leamreject
strang wrote:Just an update - I had the wheels checked for balance and they were fine. I had also developed a rattle which sounded like brake pads, but still rattled on rough ground whilst braking. Further examination has revealed that the lower bushes on the rear shocks are shot - so that is causing the rattle, hopefully once replaced it will cure the steering issue too.
I had a similar rattle over rough ground, turned out to be the mother in laws false teeth chattering… Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
21st Sep 2022 3:07pm |
