Home > Maintenance & Modifications > Defender 90 heated seat upgrade
kidneywiper
Good morning.
We have a 2013 Defender 90 that does not have heated seats. Does anyone know of a good overlay kit that we could use to upgrade to heated seats. I would like to utilise the original switches & any wiring that may already be fitted in the original harness so it looks as standard as possible.
Thank you for your time.
Post #964825 13th Sep 2022 7:19am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
I believe Brit Part supply a kit which includes heat pads looms and switches etc. to fit to your current seats. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #964826 13th Sep 2022 7:28am
rallysteve
I fitted the Waaco one about 6years ago and it has worked nicely. I only wired the higher power setting in so I could use the genuine dash switches.
I suspect the Britpart one may well be the same kit re-branded.
Cheers,
Post #964831 13th Sep 2022 8:03am
Screbble
I understand that Exmoor Trim and MobileCentre may be able to help.
Post #964853 13th Sep 2022 11:07am
